Posted: Sun Jun 07, 2009 12:02 pm Post subject: Cooling |
On normal roads 80 degrees, motorway 100. Why is this? Dodgey water pump? _________________ Fiat Bravo 165 Sport |
Posted: Sun Jun 07, 2009 2:53 pm Post subject: |
Take it you didn't go to Stanford hall as well then?
My thoughts would be that if the pump is turning at correct speed, i.e belt not slipping then that shoukld be ok. When they go caput they tend to leak and/or make a noise.
Could be blocked veins in rad, but i think you fitted a new one so probably not that?
Thermostat sticking shut? Does the rad and thermo- rad hose get hot?
Posted: Sun Jun 07, 2009 3:02 pm Post subject: |
I don't know the answers to any of those things John.... but yes, I have just come back from Stanford Hall.
I had the only 33 and there weren't many people there at all (due to the weather) although it was fine once we got there.
I'll check those things over... Thanks!
Yes, it's got a new thermostat and rad.. perhaps one's on the blink!
Posted: Sun Jun 07, 2009 4:53 pm Post subject: |
Could it be due to no heater matrix or that the gauge is out?
You could check the CTS output when it gets to 100, not mph and not whilst driving.  _________________ x2 33 16v
Posted: Sun Jun 07, 2009 6:35 pm Post subject: |
| BigAl wrote: |
You could check the CTS output when it gets to 100, not mph and not whilst driving.  |
Not a bad idea actually Al... thanks! _________________ Fiat Bravo 165 Sport |
Posted: Mon Jun 08, 2009 10:58 am Post subject: |
I'm working on the premise that it's ok standing still and ok around town, up to about 50 mph, but then at speed on the motorway the temperature goes right up.
Hmmm.... this implies (the around town bit) that the cooling system is working just fine.
Theory : could this be throttle body misalignment? As on the motorway I'm just slightly pressing the throttle which would then open only two inlets with a totally incorrect mixture for a prolonged period (as it's "programmed" for four?)
Posted: Mon Jun 08, 2009 8:30 pm Post subject: |
Firstly Bobber, do you know if the impeller on the 33's waterpump is plastic, if so it could have cracked and when pushed stop spinning when at higher rev's, a quick test would be to start the car warm it up til the fan kicks in then give it a fair bit of steady rev's to see if it does the same. My wifey's 147 had this issue and unfortunatly needed a new pump. Hope its not the problem for you as its practicly d-day . _________________ PHAT 33 |
Posted: Tue Jun 09, 2009 8:48 am Post subject: |
| If the temp isn't rising any more than 100 ie not over heating then it should be able to cope with that surely? |
Posted: Tue Jun 09, 2009 9:27 am Post subject: |
That's what I'm hoping!  _________________ Fiat Bravo 165 Sport |
johnboy 16 Valve
Posted: Tue Jun 09, 2009 3:50 pm Post subject: |
bob wire in a switch to the fan.then if it gets to hot turn it on.like it did for the track! Plus flush the system again! _________________ WODA WE NEED? MORE POWER!!
1999 freestyle superjet |
Posted: Tue Jun 09, 2009 3:51 pm Post subject: |
Thanks Johnboy.... I've already got a switch for the fan (as the thermocontact doesn't work properly!)
Yes, I'll be flushing and waxing and flossing etc...  _________________ Fiat Bravo 165 Sport |
Posted: Tue Jun 09, 2009 11:03 pm Post subject: |
Check ignition advance (not enough= overheating), proper mixture (too lean=overheating, can happen at high load if the fuel pump does not have sufficient flow), clogged exhaust (overheating once again)
JeremyC Gold Cloverleaf
Posted: Wed Jun 10, 2009 9:47 am Post subject: |
Too much advance will overheat too. _________________ '93 Black 33 1.7 16v |
Posted: Wed Jun 10, 2009 9:57 am Post subject: |
Chaps, I think it's down to the circuit not pressurizing correctly as the pressure release valve on the cap is always open. I have a replacement coming today.
Still have other leaks though around the hose clips. I think this is due to corrosion on the union joints which then stop the hoses from fitting flush against the metal. Oh well... probably need to run down the unions to a nice smooth finish and then replace all the hoses for new.
Not going to happen before SPA though.... could be interesting. _________________ Fiat Bravo 165 Sport |
Posted: Wed Jun 10, 2009 1:26 pm Post subject: |
One for the kitbag-
But I wouldn't put this sh*t in unless you're in real trouble.
Posted: Wed Jun 10, 2009 1:55 pm Post subject: |
Hmmm.... not keen on that stuff John, it's like Holts Stop Rad Leak (or whatever it's called!?!?)
Suppose it could be good to get us out of trouble if need be. This might seal leaks around the ends of hoses?
Pretty sure I've actually got some of this somewhere.
Correction : RadWeld.
Bob. _________________ Fiat Bravo 165 Sport |
Posted: Wed Jun 10, 2009 4:27 pm Post subject: |
| If you get this cap and the system pressurises properly then aren't the leaks going to become gushing geysers? |
Posted: Wed Jun 10, 2009 4:28 pm Post subject: |
Good question Lee! I would think that's logical!
We're having another good tighten up tomorrow morning before we leave... _________________ Fiat Bravo 165 Sport |
Posted: Wed Jun 10, 2009 4:33 pm Post subject: |
| Best of luck mate. All my unions are quite rusty and dont have leaks so maybe a good arnie tighten up will do the trick. |
Posted: Wed Jun 10, 2009 8:21 pm Post subject: |
if it isn't leaking then I would leave it lee, oh shit another thread response too late!!  _________________ PHAT 33 |
Posted: Thu Jun 11, 2009 9:34 am Post subject: |
| Oggie wrote: |
if it isn't leaking then I would leave it lee, oh shit another thread response too late!!  |
No Iain, i wasn't even going to look at them! Dangerous  |
Posted: Thu Jun 11, 2009 1:16 pm Post subject: |
You do have European breakdown cover don't you? _________________ '93 Black 33 1.7 16v |
Posted: Thu Jun 11, 2009 8:30 pm Post subject: |
Yep , I do, and paid extra for labour free!!!. _________________ PHAT 33 |
