DAmn You alfa Electrics! Sparks coming from steering wheel!
Matthe_W_allace
PostPosted: Thu Jan 26, 2006 9:34 pm    Post subject: DAmn You alfa Electrics! Sparks coming from steering wheel! Reply with quote
Well, not quite, but whenerver I turn the wheel alot, the section behind the steering wheel which hosts the indicator and wiper stalks and the ignition barrel, suddenly starts sparking! Then the radio switches off!
What the hell???
Bellamachinna
PostPosted: Fri Jan 27, 2006 4:43 pm    Post subject: Reply with quote
You can say that again!!!!!!!!!!!!!!
What the hell??? Shocked Shocked
Seems that you got serious electrical issues on your car... Sad
I cant give you any clue to what it can be, because i never saw any trouble like the one that you describe... Confused
Does your car have a alarm? - Most electrical troubles on Italian cars (not just Alfas), came from dodgy alarm installations...
Some onwers, install a alarm, and when it comes to sell the car, he removes it again, and the new onwer does just the same...
You can imagine the mess that creates on the electrical installation...
On my car i removed, almost 3 metres of wires that were no longer in use...
Still didnt solve the electrical passanger window, because the drivers switch operates but at snail speed...
Take the cover from the steering rack and try to locate were are the sparks comming from...Thats my best advice...
And dont drive the car until you locate and solve that trouble...
I´ve saw cars that went up in flames for no reason...
Good luck
P.Camilo
john 33 16v
PostPosted: Mon Jan 30, 2006 9:35 am    Post subject: Reply with quote
In agreement with Bellamachinna, it's probably not Alfas wiring but some iffy DIY job.
Someone has probably taken an ignition live off up near the ignition barrel or something to feed the radio. You need to remove the cowling and suss it out asap.
Matthe_W_allace
PostPosted: Sun Feb 19, 2006 9:22 pm    Post subject: Reply with quote
Haha, a broken wire was rubbing.
That will be all.
Funny!
