		Laki Alfasud
				 Posted: Thu Aug 10, 2006 4:51 pm    Post subject: Back on 33 |
				After having luck to find an OK 155 Q4 I got extremly lucky and found an 33 Q4
some pics....4x4 is not working but I am on it
Maybe som help with 4x4, when I start 4x4 ligts blinks for turns off for a second than it turn back on...I dont hear clutch engaing at any time... _________________ -- ALFA ROMEO 33 Q4 --
				 Posted: Thu Aug 10, 2006 4:57 pm    Post subject:  |
				Dober Dan Laki,
Looks like an excellent example!  Well done - and although I know NOTHING about the P4 system - good luck in sorting it out!!!!
Hvala,
		markgp4 Alfa Sprint
				 Posted: Thu Aug 10, 2006 8:15 pm    Post subject:  |
				is a q4 the same as a p4 then? _________________ make it go faster   |
				 Posted: Thu Aug 10, 2006 8:27 pm    Post subject:  |
				Mark,
Yes.
				 Posted: Thu Aug 10, 2006 9:47 pm    Post subject:  |
				Yes and No
Q4 is 33 s3 which was produced 93/94, so they share same differences as normal fwd 33 s3.
In short:
- 3 bolt mount  front shock& conical springs&top strut bearing
- instrument panel switches 3/4 size of 90-92 cube types. ( This strangely leads to some differences in wiring ie hazard lights switch)
- different interior finish grey alcantra instead of older durable textile with red/grey rombs and full plastic copy of leather on door instead of same textile as before
- was available with 14" copy of  155 Q4 rims
Laki try to search for 4x4 problem thread we had recently.
Pozdrav _________________ Tino Vatavuk
		stedee Alfa 33
				 Posted: Fri Aug 11, 2006 12:38 am    Post subject:  |
				you know your stuff dont you tino _________________ brum brum |
		Laki Alfasud
				 Posted: Fri Aug 11, 2006 6:39 am    Post subject:  |
				He centerliy does...   Tnx...will try to find something. I have got those copy Q4 rims as well and have winter tires on them.     . _________________ -- ALFA ROMEO 33 Q4 --
		stedee Alfa 33
				 Posted: Fri Aug 11, 2006 7:47 pm    Post subject:  |
				i have also just got a p4 in champagne colour ,done 36000 miles but needs heads doing (the usual cambelt slip) i`m going to get theheads skimmed and the heads ported plus i`m going to paint the engine red and clean up all the aluminium bits so hopefully it will look sweet. _________________ brum brum |
				 Posted: Fri Aug 11, 2006 8:41 pm    Post subject:  |
				You should send us some photos Steedee!
		mt Alfa Sprint
				 Posted: Sun Aug 13, 2006 9:48 pm    Post subject:  |
				Yeah Stedee, i want to see some pics too!
Nice car Laki! And cheers for the info Tino, i didn't know any of that.
Stedee, as you mentioned the belts slipping i'll mention that i've just posted about finding that my belts have stretched enough to need tensioning after only 6k miles (though i suspect they stretched quite a way before then) and as the tensioners are now at full travel (after only 6k!) i'm expecting to have to change them about 12k, maybe sooner.
Would explain why belts seem to jump so easily. |
		markgp4 Alfa Sprint
				 Posted: Tue Aug 15, 2006 5:15 pm    Post subject:  |
				Hi mt i thought you were NEVER supposed to retighten the belts??
I just did my engine, i went for black for the block tho and polished the alloy bits....
 but i dont know how to post pics here ? _________________ make it go faster   |
				 Posted: Thu Aug 17, 2006 11:56 am    Post subject:  |
				16v have very long belts and it is normal for them to strech but how much I don't know.
Mark, you cant be sure about retensioning.
Logical thinking forbids it because if you thighten streched belt it will strech even more soon or what is more likely will snap.
But what is then purpose of those 4 holes on belt covers, just around belt tensioner screws?
I think belts can be retighten after few miles or few hundreds, and that is purpose of those holes, but I don't have any worshop manual or similar to back up my thinking. _________________ Tino Vatavuk
		Laki Alfasud
