TimoJ Guest
Posted: Mon Jul 07, 2003 10:44 am Post subject: Help needed, 16v Alfacontrol manual |
Desperate need for -90 16v manual for Alfa control. At least need to know what light means what: "Efficiency" light lit up and no starting, fuelpump not running.
TimoJ (Fin) for Daddys 16v |
dd (again) Guest
Posted: Mon Jul 07, 2003 11:39 pm Post subject: Hah! |
I take the Effiency light to mean electrical problem detected
- for example blown fuse or relay or bulb in dash asembly
Check fuse/relay for pump.
I think it is in engine bay
Handbook does not state!
- dd |
TimoJ(fin) Guest
Posted: Tue Jul 08, 2003 12:40 pm Post subject: Thank You |
Thanks for the tip, checking...
TimoJ
Friend told me to throw "Alfa Control" as far as I could )) |
John Hansen Alfasud
Posted: Tue Jul 08, 2003 1:30 pm Post subject: Alfa Control |
It seems to be great when it's working! We had a problem with oil level sendert and found that if you "short" out the connection, it gives the green light. It seems to work on the basis that if you have continuity everything is OK! _________________ John H
'87 Alfa 33 QV |
Posted: Sun Jul 13, 2003 9:58 pm Post subject: |
Think they actually require a resistor to avoid the oil light coming on (12 ohm rings a bell). Think I have read that shorting them out can damage the Alfa Control unit
