Alex_Alfa33 Alfasud
Joined: 11 May 2007 Posts: 41 Location: Essex, Nr Chelmsford
Posted: Wed Oct 01, 2008 7:16 pm Post subject: Wanted: Alfa 33 1.7 16v Heads, Crossmember and Sump |
Looking for a set of 1.7 16v heads to put on my 8v block.
Apparently i will also need a 16v sump n crossmember.
Thinking about it i will probably need the pulleys as well or can i use 8v pulleys, as i have a few verniers.
If anyone can help, i would appreciate it. _________________
Posted: Wed Oct 01, 2008 9:56 pm Post subject: |
I got heads and sump. Prob. got cross member - can check. No pulleys on camshafts though, but practically new tensioners and belts. I take it you're going to want the sump-head corrugated oil channels aswell. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Thu Oct 02, 2008 11:25 am Post subject: |
Hey Alex, I thought that you needed to get the pistons milled out to accommodate the valves, like the 16v pistons are naturally, but then I heard about some guy that did what you are trying and didn’t have to, have you checked? _________________ x2 33 16v
Alex_Alfa33 Alfasud
Posted: Thu Oct 02, 2008 11:36 pm Post subject: |
| paulhide wrote: |
| I got heads and sump. Prob. got cross member - can check. No pulleys on camshafts though, but practically new tensioners and belts. I take it you're going to want the sump-head corrugated oil channels aswell. |
oh cool, that was quick. How much do you want for them? Yeah i think i will need the oil channels as well.  _________________
Alex_Alfa33 Alfasud
Posted: Thu Oct 02, 2008 11:39 pm Post subject: |
| BigAl wrote: |
| Hey Alex, I thought that you needed to get the pistons milled out to accommodate the valves, like the 16v pistons are naturally, but then I heard about some guy that did what you are trying and didn’t have to, have you checked? |
Im not going to be using the standard 8v pistons. Going to get some new forged ones to fit, so shouldnt be a problem, fingers crossed lol. _________________
