markgq4 Alfa Arna
Posted: Sat May 01, 2010 5:59 pm Post subject: 1.7ie on carbs??? |
hi people,
aint been here for ages cos i been without a flat four for nearly 2 years,
but got another sud to "fix-up"
i have a 33 1.7 ie motor and am wondering (hoping) i can run it on carbs, but seem to recall it being said that the ie wont run on carbs ??
anyone know the correct answer here?
i would use the carbs, oil pump and distrbutor and wiring from a carbed 1.7 i killed, from an s2 33 at cadwell the summer before last... ooops !
any advice much appreciated.  |
Posted: Sat May 01, 2010 7:52 pm Post subject: |
Yes it can be done but you need to replace the rear housing to install the fuel pump. Be sure to keep the ie flywheel.
Greek Alfasud
Posted: Mon May 10, 2010 2:22 pm Post subject: |
yes but keep in ming that you will have only 110hp instead of 118 due to diferences in Ie and non cat versions...... |
