16V Shrew Alfa Arna
Posted: Mon Dec 12, 2011 12:32 am Post subject: tuned or hot 16v engine or parts wanted |
hi guys
it won't belong before i'm pulling my motor out, and rather than put it back in stock, or put it back at all, i'd like to know if anyone has any tuned engine parts up for grabs?
complete engines, bigger bore stuff, worked heads etc etc but must be pretty much good enough to bolt on/in, or require as little work as possible, hopefully.
please send any info to shrew.shrew@ntlworld.com, or ring me on 07875 749472
cheers
shrew _________________ Petrol Head till I Die! |
16V Shrew Alfa Arna
Posted: Tue Dec 13, 2011 1:26 pm Post subject: |
bumpety bump bump!
c'mon chaps, does no-one want to part with anything? or are there just no bits out there? _________________ Petrol Head till I Die! |
16V Shrew Alfa Arna
Posted: Sat Jan 07, 2012 10:12 am Post subject: |
is there really no good engine bits out there?
carbs, throttle bodies, heads, cams, pulleys, blocks, pistons,
anything? _________________ Petrol Head till I Die! |
Posted: Sat Jan 07, 2012 6:32 pm Post subject: |
think you ought to try posting on Alfa racer, those of use who have spent fortunes on specialist parts like to keep hold of them. _________________ PHAT 33 |
16V Shrew Alfa Arna
Posted: Sat Jan 07, 2012 7:27 pm Post subject: |
good idea ian
ta mate _________________ Petrol Head till I Die! |
Posted: Mon Jan 09, 2012 2:15 am Post subject: |
Contact Peter on 07510 534712 or email him on alfastore@googlemail.com. He is a good friend of mine and has a few sets of pistons & rings, crank bearings and also soon to get new engine blocks. I'm sure he can help. If you are in my area on Tuesday he will be here exchanging a load of bits so pop along to pick brains if you wish.
PS, (sorry for the late reply to your last text, have just done so).  _________________ 155 sportpack
