Posted: Fri Nov 28, 2003 3:44 am Post subject: 1500/1700 differences? |
Can anybody tellme if there is any difference between the 1500 and 1700 heads apart from the inlet valve size? After driving daughters 1700 I've decided to look out for a 1700 for mine, but I'd like to do the samehead mods I did when I rebuilt my 1500 as they made quite an improvement throughout the rev range. I've got some spare 1500 heads and I could start moding them while I wait for a motor to turn up. Also I want to convert the 1700 to solid lifters as well. I can get the heads reseated for the bigger inlets but it would be a waste of time if the ports were much different. Look forward to some info.
Peter D Alfasud
Posted: Fri Nov 28, 2003 1:08 pm Post subject: 1500/1700 differences |
Yes, the cylinder heads are different on 1500 and 1700.
On 1700 a part of the combustion chamber is recessed in the cylinder heads.
If you try to fit 1500 cylinder heads on a 1700 you will get compression ratio of about 20:1 !
You will then have to modify the 1700 pistons as well.
Peter (DK) |
Posted: Fri Nov 28, 2003 10:28 pm Post subject: |
Thanks Pete
Thats what I needed to know. I thought it couldn't be that simple.
Matt Stolton Alfa Sprint
Posted: Fri Dec 05, 2003 10:40 pm Post subject: Don't mean to be an arsehole but... |
the obvious difference is about 200CC
I had to say it before gary got it in... _________________ Regards
Posted: Sun Dec 07, 2003 11:22 am Post subject: |
Thanks Matt
My calculator don't count that high but I was talking about the heads. Always read the fine print.
