Matty Dog Alfa Arna
Joined: 07 Dec 2003 Posts: 21 Location: Wellington, New Zealand
Posted: Sun Feb 01, 2004 10:31 pm Post subject: 16V Head removal |
I need to pull the head off my 16V motor to get access to bent valves.
I've dropped the motor, removed the cam-cover and found a row of charming 12-point cylinder head bolts. Put there to keep people like me out, no doubt.
I phoned the local engineering supplies shop who say these are called "tri-square". They don't have the tools in stock, but can order them at vast expense. Apparently I can also use a Torx for this, although it's not the ideal tool for the job.
What size Torx or Tri-square socket/bit do I need?
Matthew |
Posted: Sun Feb 01, 2004 11:52 pm Post subject: Re: 16V Head removal |
Hi matt
It's a T55 bit, you should be able to get it from any good tool shop
Matty Dog Alfa Arna
Posted: Mon Feb 02, 2004 8:57 pm Post subject: |
Thanks John,
I bought a T55 bit and it fitted perfectly.
Dropped the head off at the reconditioners before work this morning.
Looks like 2 exhaust valves are a bit bent.
Time to ring the Italian Auto Centre...
*Credit card cowers and whimpers!*
Matthew |
Posted: Tue Feb 03, 2004 3:57 am Post subject: |
Hi Matt,
how bad are the valve's? as i bent one and my mate straightened it for me by hitting it with a bit of nylon and a hammer. reseated no problem's,try that first.if they brake buy new one's, nothing lost. it's wurth a go!
Matty Dog Alfa Arna
Posted: Tue Feb 03, 2004 9:04 pm Post subject: |
I've heard of valves being straightened, but I'm a bit sceptical.
However, my scepticism is not based on any scientific knowledge or personal experience.
I would be worried that having the valves bend and then bent back, that they would be weakened. Then at 2am on a country road at 7000rpm, the valve would snap and become intimately involved with the head and the piston.
As the cost of 2 new valves is only a small part of the cost of the whole job, I've ordered new valves for my own peace-of-mind.
I take it your motor is still running strong, John.
Any 33-owning Metalurgists who can comment on straigtening valves?
Matthew |
Posted: Wed Feb 04, 2004 12:56 pm Post subject: |
Hi Matt
i can see where your coming from,but my valve was just abit bent,i can email you photo's of the side i killed, that's a different kettle of fish,all eight valves where bent big time!! as for my engine now strong as ever,ive red lined it to 7400 with no problems. fingers crossed it will stay like that good luck with your car
Matt Stolton Alfa Sprint
Posted: Fri Feb 06, 2004 10:14 am Post subject: Don't try and straighten valves |
By beating the valve, or any metal for that matter, you are mechanically altering the crystal structure of the metal, not normally for the better.
When the valves are made, they are manufactured in a certain way to maximise strength, durability and suitability for being a valve. This includes a strict regime for cooling the molten metal to solid. It is this that gives the metal/alloy a lot of appropriate characteristics. A metal plunged into cold water from 1000C will have different charcteristics to one air cooled slowly from the same temperature.
By smacking it, which, by doing 'work' to it, heats up the crystals, it will have become brittle around the area of the bend. For the price of a new valve, against the cost in time/money to have to get back into the engine to replace the brittle valve, I would always replace, not bodge. _________________ Regards
Posted: Fri Feb 06, 2004 7:48 pm Post subject: Re: Don't try and straighten valves |
I would always replace, not bodge.[/quote]
Well it was only very slightly bent, plus my mate who did it, built the lister storm chassis that won the FIA GTR WORLD CHAMPIONSHIP IN 2000-2001 he's not a bodger! _________________ WODA WE NEED? MORE POWER!!
