Replacing the lower spring 'disc'
Pilota33
PostPosted: Fri Nov 19, 2004 7:22 pm    Post subject: Replacing the lower spring 'disc' Reply with quote
Well, to start with, I have no idea what the part is called like in english, but can the the lower 'disc', that holds the front spring of a 33 be replaced?
I'm talking about the 'new' version of the springs that are being mounted with the 3 bolts on top.
Serge
It's Alfantastic!!
'79 Spider 2000 Veloce
'83 AlfaSud Sprint Veloce 1.5
'83 33 1.5
'87 33 1.7 iE 16v (chipped)
'88 33 1.7 QV (A/C)
'93 33 1.7 iE S 16v Q4 SW Zender (A/C)
bobbber
PostPosted: Fri Nov 19, 2004 7:35 pm    Post subject: Reply with quote
Hmmm.... can you identify it on this diagram??? :
http://www.alfa-restoration.co.uk/img.bmp
Fiat Bravo 165 Sport
PostPosted: Fri Nov 19, 2004 8:19 pm    Post subject: Reply with quote
Is it bit 4 is the lower spring mounting plate?
Replacement part from the Alfa dealer or specialist.
If it's holed, thin or rotten replace it.
Worth doing the bearing (19) at the same time for smoother steering.
Costs about £30 for both parts.
Pilota33
PostPosted: Sat Nov 20, 2004 12:18 am    Post subject: Reply with quote
It is part 4, but note, it is for the newer model 33, a post '93 model with the mounting at the top with three bolts.
I know the 4 bolt version is replacable, but is the threee bolt version also replacable?
It's Alfantastic!!
'83 33 1.5
'88 33 1.7 QV (A/C)
bobbber
PostPosted: Tue Nov 23, 2004 1:15 am    Post subject: Reply with quote
Hmmm...... like here :
http://www.alfa-restoration.co.uk/img2.bmp
Looks like it's either one peice on the strut, or not available!?
RFlower
PostPosted: Tue Nov 23, 2004 1:29 pm    Post subject: Reply with quote
Looks like they've moved the bearing from below to above the spring, so the spring turns with the strut, which I think is more conventional.
If this is the case the design is completely different from the previous one, but maybe the whole strut could be changed for the older type? - both sides would probably have to be changed, and new mounting holes drilled.
It also could be possible to carefully cut away the rusted spring support, after accurately marking its orientation, and weld in a new, old type support in the correct position.
Pilota33
PostPosted: Wed Nov 24, 2004 8:56 pm    Post subject: Reply with quote
Yep, the second picture is the one. In the meantime I found out that indeed it is fixed tot the strut. Welding could be a temporarily option, but i prefer to replace
.... well, in the meantime I replaced now... I replaced the whole car Wink I sold it (told the new owner about the problem) and have a Sprint Veloce now (see signature).
But to continue the spring support story, it seems that the later version, with the three bolts on top is a much imrpoved system, but only when the supports rust away you'll have a problem. No bearing problems anymore though..
Btw. when I mounted new 'discs/spring supports I always treated it with Tectyl as protection.
It's Alfantastic!!
'83 33 1.5
'88 33 1.7 QV (A/C)
