Timing Belt Replacement - 8v Hydraulic Tappet Engine.
adh
PostPosted: Tue May 03, 2005 10:14 pm    Post subject: Timing Belt Replacement - 8v Hydraulic Tappet Engine. Reply with quote
I think the title says it all.
Could someone please tell me what the procedure for timing belt replacement replacement is, as I understand that it is different to
that for solid tappet engines.
Thanks for your help.
Ad.
ZeNiTh-PbArM
PostPosted: Fri May 06, 2005 8:10 am    Post subject: Reply with quote
The procedure is the same for hydraulic tappets, except that the timing marks on the camshafts have moved to the pulleys. when engine is at timing point you should see the two notches of each pulley through the "window" in the cover.
best regards,
zp
adh
PostPosted: Fri May 06, 2005 8:33 pm    Post subject: Hydraulic Valve Timing Belts Reply with quote
Thanks for your help zp and for the image.
I shall venture into my garage now and check out my notches.
all the best
ad
