		Reis Alfa Arna
  Joined: 21 Jul 2004 Posts: 10 Location: Almada - Portugal
				 Posted: Fri May 13, 2005 12:34 am    Post subject: Alfa 33 1.5 IE (cat) -Stopped !! |
				I don't know what happened ! I went with my car to a carshop and after that he didn't work anymore. The current don't reach the spark plugs. Any tip please. Help !Thanks
Reis |
		ChrisC Alfa Sprint
				 Posted: Fri May 13, 2005 8:58 am    Post subject: erp |
				garage broke it, garage can fix it. tell em.
What work was it having done? _________________ Alfa Sprint QV - Gone to a better home and in happier health for it
		Bellamachinna Alfa 33
				 Posted: Fri May 13, 2005 3:28 pm    Post subject:  |
				Hi...
If plugs dont have spark, problem can be on the distributor/rotor arm, ignition coil.
In an worst case it can be the ECU itself, that has died. Check the relais of the ECU, to see if electrical power reaches the ECU.
Start by the least expensive and go from there.
What job did the garage do?-Were they just changing oil, or did you ask them to do an extensive job??
Did they mess any electrical connection?
If its they fault, they must put it back in order...
Keep in touch
J.Oliveira _________________ All'interno della mia macchina, vi sedete, tenete sopra e CHIUDETE IN SU... |
		Reis Alfa Arna
				 Posted: Sat May 14, 2005 2:58 pm    Post subject:  |
				Thanks for your reply Oliveira.
It seems that the coil it's ok but the ECU, one transistor have blow up!
I have a friend and will try to repair if possible. I hope to have an identical ECU to verify with the car if anything else is wrong. Next week I hope to have further news and I will inform you accordingly.
Regards (Cumprimentos)
Reis |
		Reis Alfa Arna
				 Posted: Tue Jun 07, 2005 10:56 pm    Post subject:  |
				The ECU (Centralina) is dead ! It´s very difficult to buy one cheap, and to find it is very,very difficult. I'm keep trying.
Regards to you all
Reis
PS.One think that I have learned: NEVER clean electrical contacts wity BATTERY ON ! And if so, after you connect the battery please allow at least 1 minute before start engine ! Because the ECU must restart and check all motor circuits. |
				 Posted: Wed Jun 08, 2005 6:50 pm    Post subject:  |
				Hi...
Sorry to hear about your car problems...
However, try the salvage yards at Sacavém. There is one, on the top of the road on the left side that has a great deal of new & used parts for Alfas   .
Try also Porto Alto & Montijo.    If theres nothing there, you`ll probably will have to go to a new one...And pay a lot of cash...
Hope this helps
		Laki Alfasud
				 Posted: Thu Jun 09, 2005 1:57 pm    Post subject:  |
				Sadly I am from SLovenia.....If you wont be able to finded in Portugal I can ship it to you . My price is 0 ponuds and you pay post an pacakge...If you intrested let me know...  Have 2 at home dont know what to do with them    _________________ -- ALFA ROMEO 33 Q4 --
		Reis Alfa Arna
				 Posted: Mon Jun 13, 2005 12:53 pm    Post subject:  |
				Thanks for your attention and help.
It's really very difficult to find here in Portugal the ecu 261 200 658
Reis |
