Horizontally Opposed Alfasud
Posted: Sat Jul 16, 2005 1:42 am Post subject: Alternator light when starting |
This doesnt seem to be a big problem but it is a bit annoying and I don't see a reason why it should happen.
Why does the alternator light stay on until you rev to +-1500 rpm just after you've started the car?
After going up to 1500 it doesn't light again even if the rpm drops back to idle.
Why does this happen??
When the light is on you can also see the lights are a bit dimmer and everything electrical doesn't seem to get enough power.
I've seen this in 2 more series 3 besides mine.
Isn't it a bit weird? |
BILL Alfa Sprint
Posted: Sat Jul 16, 2005 7:26 am Post subject: |
| Same thing happens to my 33.Unless i rev over 1500 it does stay on.It might have to do with the relay in the alternator.I am used to it so i doesnt bother me anymore |
Posted: Sat Jul 16, 2005 8:41 am Post subject: |
AFAIK it's factory feature, it has to be that way. I once knew why and it made perfect sense, but I don't any more . Something to do with protecting electrics. _________________ Tino Vatavuk
Posted: Sat Jul 16, 2005 9:16 am Post subject: |
According to the manual and specifically the BOSCH alternator, it is clearly stated that output starts at 1500 rpms.
Probably it has to do with the voltage regulator since receiving more current than in 1000 rpms it switches the supply from the battery to the alternator.
It is normal.
Bellamachinna Alfa 33
Posted: Mon Jul 18, 2005 4:51 pm Post subject: |
Hi...
All my 33`s did this...
Always thougt about it, as character....
BUT...(there`s always a but), when turning on, several electrical acessoires, the light MUST remain off.
On an previous S2, the light would start to glow (not completly on).
Changed the voltage regulator (rebuilded the alternator also), and everything back to normal..
hope this helps
ChrisC Alfa Sprint
Posted: Tue Jul 19, 2005 12:14 pm Post subject: hmm |
I get the overheat warning light as well till its been > 1500rpm because im special. Im planning on whipping the fusebox out and cleaning it out. _________________ Alfa Sprint QV - Gone to a better home and in happier health for it
