bialbero2003 Alfa Arna
Posted: Thu Jul 21, 2005 12:40 pm Post subject: Alfa 33 16V External Engine Dimensions |
Hi all,
I am considering putting a 33 1.7 16V into another vehicle.
I did a search but could not find any external measurements.
Could someone please give me the following dimensions:
1=length from gearbox mating flange to crank pulley
2=Width of widest point (across plastic cam covers?)
3=Height from sump bottom to top of injection setup
4=Distance from crank centerline to bottom of sump
I would much appreciate even rough measurements
Nick |
manuel164 Alfa Arna
Posted: Thu Aug 04, 2005 12:02 pm Post subject: |
Hello!
Next week i will put an 16v out of the car, then i can give you the measurements you want.
greets
manuel _________________ Alfa 33 16v preparing for Race |
Posted: Fri Aug 05, 2005 12:40 pm Post subject: |
Hi Manuel,
that would be great if you could get the measurements, I am not in a hurry.
There just are'nt too many around to go and take measurements from anymore.
Nick |
manuel164 Alfa Arna
Posted: Fri Aug 12, 2005 2:13 pm Post subject: Re: Alfa 33 16V External Engine Dimensions |
~480mm
~820mm
~240mm to the top of the rubberconnections
~220mm _________________ Alfa 33 16v preparing for Race |
Posted: Thu Aug 18, 2005 3:13 pm Post subject: |
Hi Manuel,
thanks for your help.
Those measurements will help great to see if the 33 16V will fit into what I am considering.
Nick |
LDA Alfa 33
Posted: Thu Aug 18, 2005 3:32 pm Post subject: Re: Alfa 33 16V External Engine Dimensions |
just had a look round my car with a tape measure and they seem to be about the right sizes.
