micap Alfasud
Posted: Sat May 10, 2003 11:26 am Post subject: Carbs on an injection engine. |
I am thinking of buying a 33 with injection and then bolt on the carburettors from the one I have now. What kind of changes does that require? Parts wont be a problem since I have a complete carb model to steel from. _________________ /Michael
ex 89 1.7 QV
Posted: Sat May 10, 2003 12:25 pm Post subject: |
Shouldnt be a problem. You might need to swap over the intake manifold from your spare engine though. You also might have problems if the injection engine is from a later 33 with motronic injection as they were not equiped with distributors
Mixsynth Alfa Sprint
Posted: Sat May 10, 2003 1:03 pm Post subject: |
I presume it's a 1.7ie (8V) you're getting? _________________ Hugh B
'98 145 QV
micap Alfasud
Posted: Sat May 10, 2003 2:29 pm Post subject: |
It's a 1,7 8v ie from 1990, so I guees it wont be a problem with the injection system then? _________________ /Michael
ex 89 1.7 QV
Posted: Sat May 10, 2003 2:40 pm Post subject: |
Nope, that's great. Exactly as Keith says - should bolt straight on (and do include the carbie inlet manifold). _________________ Hugh B
'98 145 QV
micap Alfasud
Posted: Sat May 10, 2003 5:44 pm Post subject: |
What about the fuel pump and lines? I've heard that they should be changed too. And anything else? _________________ /Michael
ex 89 1.7 QV
Posted: Sat May 10, 2003 7:54 pm Post subject: |
The carb car fuel pump is on the engine. Dont know if there will be a facility for it on the inhected engine, so you will have to check that. You dont need to worry about the fuel lines and pump as you are (I think) intending to use the carbs (if you were fitting the engine complete with fuel injection then you would need to change the fuel lines and wire in a high preasure fuel pump, etc)
Posted: Sun May 11, 2003 8:03 am Post subject: |
I should be added that you can't use the pump setup from an injected car - the pressure will be far too high for the carbs. Either mechanical pump or low pressure electric pump should be used - you only need about 3-3.5 psi for webers/dellortos.
Lex |
Maximilian Alfasud
Posted: Fri May 23, 2003 10:46 pm Post subject: |
If your fitting the carbs, you should remove the catalytic converter as well.
With these modifications you may not pass your country's emissions rules for newer cars. _________________ 1988 Sprint 1.7 QV (35,000 miles) |
Serpent33 Alfa Sprint
Posted: Wed May 28, 2003 2:45 am Post subject: Re: Carbs on an injection engine. |
micap wrote: |
I am thinking of buying a 33 with injection and then bolt on the carburettors from the one I have now. What kind of changes does that require? Parts wont be a problem since I have a complete carb model to steel from. |
I did the conversion recently with the help of some guys here.
-distributor
-carb with linkage
-fuel pump for carbs(mine is an electric low pressure pump from a honda)
-throttle linkage
-preferably your QV exhaust as well(they're unique for 1.7QV)
Good luck!
please let me know whether the QV has a longer ratio. Thanks. Coz my experience with a few QV gearbox is that they are slightly longer. I need to confirm. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Tue Jun 10, 2003 12:11 am Post subject: |
At the top of the screen there is an icon towards the left that looks vaguely like a pair of gears (I know, I cannot draw). Click on that and you will find a list of most of the gear ratios used in the Sud and 33.
Posted: Tue Jun 10, 2003 12:58 am Post subject: |
Been there. But somhow the spec is not what I experience. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
arci_331,7 Alfa Arna
Joined: 24 May 2005 Posts: 9 Location: Pireaus,Greece
Posted: Tue May 31, 2005 1:09 am Post subject: |
Whats te reason to do that? 110 hp for the ie and 118 for the carb one...But ist easier just to reprogramme the ie??? I also have the 1,7 8v ie and seems to be fast enough.... isnt she? |
Posted: Tue May 31, 2005 10:18 am Post subject: |
You're missing the point - carbs are cooler!  |
Serpent 33 Guest
Posted: Thu Jun 02, 2005 12:19 pm Post subject: |
Can someone direct me to another forum where I can get good advice on carb settings? Tried asking here many times but had no answer. Thanks. |
