nitram Alfa Arna
Posted: Sun Nov 06, 2005 11:30 am Post subject: p4 for sale - isle of skye |
Just testing the water, got a h-reg p4 mot'd till december and as you probably have read its dropped a cam belt tensioner so needs engine work and i really dont have the time.
Good points -
tidy body, no major rust issues, bodywork very good and underneath is solid, needs a patch in boot next to washer bottle, but thats all ive noticed
Interior clean and complete
4Wd worked ok, knocked a bit on full lock and there was a slight whine between 60 and 65mph, but thats all.
bad points,
dropped a cam tensioner on passenger side so needs engine investigating or changing
Needs steering rack changing as it leaks, but i have 2 spare
also I have good spare p4 gearbox, viscous coupling, 4wd computer and wiring loom, prop and lots of other stuff - headlights, indicators, switches,clocks,servo etc etc etc which would all go with the car.
Biggest pain is im on the isle of skye and it will need trailering, im on the NW end of the island in harlosh sw of dunvegan
If your interested make me a silly offer, i realise its a pain to come and get but i want the car to go to an enthusiast rather than it rotting away up here.
If you want more info/pics let me know
cheers for reading
martin  |
nitram Alfa Arna
Posted: Fri Nov 11, 2005 6:31 am Post subject: |
Is nobody interested in this then?
Ill maybe stick it on ebay then. Will post link when its done.
cheers
martin |
kaBOOM Alfasud
Joined: 11 Apr 2005 Posts: 50 Location: Adelaide, South Australia
Posted: Mon Nov 14, 2005 8:46 am Post subject: |
I live in Australia
/me screams at the wall _________________ All of the worlds problems can be solved by positive manifold pressure  |
Posted: Tue Nov 15, 2005 6:48 am Post subject: |
Shame about that - postage would be too much i guess.....
No takers then.....may fill it with concrete and use it as a mooring for the boat then
(dont mean that - just winding my brother up ) |
kaBOOM Alfasud
Posted: Thu Nov 17, 2005 7:59 am Post subject: |
| Anonymous wrote: |
ARGH!!!!!!!!!!!!!!! _________________ All of the worlds problems can be solved by positive manifold pressure  |
nitram Alfa Arna
Posted: Sat Nov 19, 2005 6:53 am Post subject: |
