The Eagle has Landed - My New P4: Pics
tempra2
PostPosted: Fri Mar 30, 2007 8:15 pm    Post subject: The Eagle has Landed - My New P4: Pics Reply with quote
Thanks for all the help and advice, here's some pics the PO took whch he's kindly let me post:
*Piccys*
55K, FSH and it's as good as it looks! Cool Very Happy
tvatavuk
PostPosted: Fri Mar 30, 2007 9:03 pm    Post subject: Reply with quote
She's a Beauty Smile
Is that metalic dark grey dark beast behind also yours?
Tino Vatavuk
tempra2
PostPosted: Fri Mar 30, 2007 9:21 pm    Post subject: Reply with quote
Hi Tino!
Sadly not, that's the previous owners 3.2 facelift. He also owns an SZ - top bloke (Obviously: the cars say it all!) Very Happy
PostPosted: Mon Apr 02, 2007 7:30 am    Post subject: Reply with quote
Minter! Very Happy
Enjoy
33 16v '93
145 2.0 Clover '97 (The wifes - sort of!)
tempra2
PostPosted: Mon Apr 02, 2007 10:38 am    Post subject: Reply with quote
Cheers John!
This is what I spend yesterday doing: Service items
Only had 5 hours, but managed to:
- Replace the cracked coolant hose from the T’stat to the left side intake.
- Replaced all the other hoses to the t’stat as a precaution and the T’stat itself.
- PAS and Alternator Belts
- Flush and change the coolant
- Change the Engine Oil and filter
- Change the Diff Oil
- Change the Air Filter
- Change the dissy cap and rotor arm
Still need to:
- Change the gearbox oil (The oil from the diff was as new, so I’ve got high hopes that the gearbox oil will be the same).
- Change the fuel filter
- Change the PAS fluid
- Change the plugs
- Take some photos of the goodridge hoses for Tino(!)
- Do the brakes: New lines, discs, fluid and pads – still waiting for the front discs!
PostPosted: Mon Apr 02, 2007 8:14 pm    Post subject: Reply with quote
I'm assuming you've had a 33 before?
If not, the plugs are a right old fiddle the first time, mostly working by feel with the plug spanner from toolkit. It looks like your p4 has been cherished, so hopefully the plugs will have been previously 'coppaslipped' which helps alot. Take out the airbox, and place a good book or magazine on the intake manifold!
tempra2
PostPosted: Mon Apr 02, 2007 9:08 pm    Post subject: Reply with quote
Thanks John; yes had a 16v before, but it was cat so the plugs were platinum so I never had to change them.
Got the tools in the kit fortunately, but yes it looks like a PITA!
My specialist advised against the cost of platinum plugs saying that the 16v's always flood and then won't start and the only way to get them going again is to change the plugs. Ever heard of this? My old car was always fine Question
PostPosted: Tue Apr 03, 2007 8:56 am    Post subject: Reply with quote
Never known my 64,000miler 16v (with cat) to flood in the 6 years i've had it.
Mine has the platinum plugs, which i've had out a couple of times. I've actually got a brand new set of platinums i got cheap on ebay, which i may whack in when i next service the car if i'm feeling very keen.
Have resprayed nsf door and spoiler in the last 10 days, waiting on brand new marrelli new nsf electric window reg assy (ebay!), then hoping for some time to put in new headlights, new front shocks and strut bearings.
Spent all free time last weekend servicing and tidying the wifes 'new' 145.
Trying to get to Spring Alfa Day for the morning, hope to see you and the p4 there!
Bellamachinna
PostPosted: Tue Apr 03, 2007 3:06 pm    Post subject: Reply with quote
Mine does this IF i use the Golden Lodge plugs. It looks like yours, but is the front wheel drive version.
If i use the Golden lodge plugs, especially in damp weather, the car as a tendancy to flood, and the only way to start the car again, is to remove the plugs and clean them....
I switched to NGK plugs, because eventualy they also flood, but the car starts on 3 cylinders, and after warming up, it "switches" the "dead cylinder into life...
I`ve tried everything, to prevent this from hapening (from new injectors, new fuel damper, new plug leads, new plugs, new distributor...The list is long) but sometimes (in damp weather) he fires on 3 cylinders..
When someone gets the cure for this i will be happy to know...
P.Camilo
P.S.-By the way your car looks Awesome
tvatavuk
PostPosted: Tue Apr 03, 2007 4:38 pm    Post subject: Reply with quote
Camilo,
friend of mine owned FWD noncat 16v with similar but worse problems, he would start engine on two cyls, fuel consumption was from 15-30% more....
He replaced fair bit of things he could replace/plugs,sensors... and check out... after he sold it new owner changed wiring and voila new car.
Tino Vatavuk
tempra2
PostPosted: Wed Apr 04, 2007 11:24 am    Post subject: Reply with quote
Oh Good - I bought NGK's so hopefully it'll at least go in the morning!
FYI: I asked the specialist if there was anything I can do to prevent the flooding on startup - he said never touch the accelerator on startup helps - don't know if it's true though.
Bellamachinna
PostPosted: Wed Apr 04, 2007 3:38 pm    Post subject: Reply with quote
What wiring did he change???
The wiring for the ECU, or the "normal" wiring???
Or did he changed EVERYTHING????
Yes this is true... But if your car has some vacuum pipe disconnected (like mine had) it simply doesnt start at all, if you dont give it a kick in the pedal...(this problem is already solved in mine)
P.Camilo
daniiodtb
PostPosted: Thu Apr 05, 2007 11:32 am    Post subject: Reply with quote
Real beauty and great seats Recaro Smile This is my first post on this page and I am happy I could write on your site. Very Happy
bobbber
PostPosted: Thu Apr 05, 2007 3:09 pm    Post subject: Reply with quote
Welcome to Alfa Pages! Very Happy
A new thread telling us a bit about yourself and some photos of your 33 would be great!
Thanks for joining!
Bob
Fiat Bravo 165 Sport
paddy granger
PostPosted: Mon Apr 16, 2007 12:54 pm    Post subject: Reply with quote
Nice one! How I miss my 33...
Looks like it has had a good history of owners, well done for finding this one.
twinspark
PostPosted: Tue Apr 24, 2007 2:08 pm    Post subject: Reply with quote
Thats very nice mate!
Not alot of difference externally to my Cloverleaf, headlight washers and the different alloys, are they 15's?
....... I want to get badges on the side of mine now after seeing yours! Smile
P17SUT - tourismo internazionale
tempra2
PostPosted: Wed Apr 25, 2007 9:41 am    Post subject: Reply with quote
Cheers Twinspark - they the boggo 14" P4 alloys, which I'm quite happy with.
Don't think you can get the small cloverleaf stickers anymore, just the right big ones Shocked
twinspark
PostPosted: Wed Apr 25, 2007 10:44 am    Post subject: Reply with quote
Maybe should just leave my standard 14's on then......unless I can find a nice set of 155 15" in the split rim style!
I've found plenty of the large side stickers on ebay, but abarth-badges have small proper metal ones for £21 each!.......think i'll just get the big stickers for £3. Smile
