		greencloverleaf Alfa Arna
  Joined: 17 Mar 2003 Posts: 1 Location: Milton Keynes, UK
				 Posted: Mon Jun 30, 2003 11:01 am    Post subject: Dead 33 16v :-( |
				I was 'making progress' down the M40 yesterday, when my 33 just died. She stuttered a bit, then died, and won't start up anymore.
I've tried a new dizzy cap and rotor arm, but still nothing.
The RAC patrol that picked me up reckoned I could have skipped a tooth on the timing - but this seems unlikely to me, given that there's 2 belts - both skipping at the same time sounds unlikely.
When I replaced the cap and rotor, I tried to fire her up, got a massive backfire and then nothing again. Like I was flooding the engine.
It seems I have sparks and I have fuel, so any ideas as to what this could be?
I'm desperate to get her back on the road, as we're down to one working car now
Steve. |
		Ketil-no Alfa Arna
  Joined: 08 May 2003 Posts: 20 Location: Bergen-Norway
				 Posted: Mon Jun 30, 2003 12:16 pm    Post subject: Re: Dead 33 16v :-( |
				There is a chance that you have snapped one of the camshaft belts. Have you checked that?
When you had the backfire you may have damaged the air-flow meter. I once broke the flap in the air-flow meter in a backfire....
Ketil |
				 Posted: Mon Jun 30, 2003 4:09 pm    Post subject: re : dead engine |
				hi
what do you mean, you have fuel? if you just checked the pump, that's not enough, i've already had the case of a faulty fuel pressure regulator causing the car to die : plenty of gas, but goes back to the tank...
		Yvon Alfasud
  Joined: 22 Apr 2003 Posts: 31 Location: Wavre, Belgium
				 Posted: Tue Jul 01, 2003 10:02 pm    Post subject:  |
				Hello,
In my research for my bad running 16V, I dismantle the heads of my first engine.  The one that was backfiring.  One camefollower is dead and cameshaft worn.
I'll try to retrieve a picture to show you.  Hope this is not what your engine have but I'm a bit afraid when I see how it happens.
I'm now busy to rebuild the heads.
Ciao
Yvon |
		Yvon Alfasud
				 Posted: Wed Jul 02, 2003 7:54 am    Post subject:  |
				Here is the picture :
That is the cylinder 4 last exhaust valve.  Camefollower is so worn that he break and worn cameshaft too.
Ciao
Yvon |
		Gary UK Alfa Sprint
				 Posted: Wed Jul 02, 2003 9:42 am    Post subject:  |
				| Yvon, what were the rest of the cam lobes like on the other cam shafts as both lobes in the picture seem very worn.  Do you know why this happened (blocked oil way?). |
		Yvon Alfasud
				 Posted: Wed Jul 02, 2003 12:46 pm    Post subject:  |
				Hello Gary,
Oil way was not blocked.  As far as I know, camefollower start to wear with the lobe came.  On another camefollower, I can see the surface is not plane but curved.  I guess curve increase until thikness is so thin that it breaks.
As for the cameshaft, PO should ear something but continue to drive the car because I do not find anything in oil, in the head.  I don't think the lobe break, just wear by the follower.  Admission cameshaft is good and ont this one, the 2 other lobe (cyl 1) is ok too.  I order a new one and I'll be able to compare lobes and also I'll replace ALL camefollowers.
I'll put the picture with the other camefollower and the full cameshaft this evening.
Ciao
Yvon |
		Yvon Alfasud
				 Posted: Wed Jul 02, 2003 10:39 pm    Post subject:  |
				Gary,
Here are the pictures
This one show you both cameshaft.  Admission is in front and worn lobe is behind on the right side
This picture show you how camefollower wear. Centre is curved by lobe movement until it breaks
And this is the broken one
Ciao
Yvon |
