CSC Manifold
Goto page 1, 2  Next
Rich B
PostPosted: Mon Jan 14, 2008 11:11 pm    Post subject: CSC Manifold Reply with quote
Well I decided to cancel my previous order after waiting 15 months and ordered direct from CSC. Ordered on 2nd Jan, delivered on 10 Jan!!!! Bit of a difference eh? Goes to show it pays to cut out the middle man.
Looks quite similar to standard manifold from memory but I'm sure it'll be slightly different and have a better flow otherwise it'd be pointless CSC developing it. All I've got to do now is rebuild my car so I can fit it!!!
1994 33 16v
2008 Alfa 147 Ducati Corse Q2
gritsop
PostPosted: Mon Jan 14, 2008 11:56 pm    Post subject: Reply with quote
Looks very nice! I DO like the wording in the wrapping ... "Marmitte" Laughing
What is the difference of the CSC manifold compared to the standard crossover one?
Thanassis Gritsopoulos
Rich B
PostPosted: Tue Jan 15, 2008 6:50 am    Post subject: Reply with quote
I believe marmitte is the Italian word for exhaust...
I'll compare this one to my standard crossover manifold, I'm sure they must be different, I need to justify the vast expense (it was 450 euros!!)
1994 33 16v
PostPosted: Tue Jan 15, 2008 9:55 am    Post subject: Reply with quote
Looks great. Just like one i had years ago on a sud, when they were called ANSA. With complete ansa system exhaust note was deeper and power kicked in like a turbo at 4,500rpm-6,000.
Only drawback (apart from cost!) was ground clearance.
Standard cat crossover manifold links same cylinders, ie pairing fronts and backs, but has awkward pipe around sump, for clearance/shortness.
johnboy
PostPosted: Tue Jan 15, 2008 10:36 am    Post subject: Reply with quote
Hi Rich
Does that mean your other crossover will be for sale Wink
regards john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
Rich B
PostPosted: Tue Jan 15, 2008 3:13 pm    Post subject: Reply with quote
john 33_16v wrote:
Thanks for the photo John, its a great help - my standard manifold is still on the engine thats sitting on the floor of my garage so it would've been difficult to clearly see the difference. I'm very relieved to see they're quite different and good to hear you noticed a difference. I will report once fitted (although this could be rather a long time away!)
ANSA are still going by the way.... www.ansamarmitte.it
Yes Johnboy, standard manifold will be sold on, let me know if you're interested and I'll try to remove it from the engine for you.
1994 33 16v
johnboy
PostPosted: Tue Jan 15, 2008 11:43 pm    Post subject: Reply with quote
Hi rich
yes i could be chap if it's a crossover type Wink
regards john
Rich B
PostPosted: Wed Jan 16, 2008 12:07 am    Post subject: Reply with quote
yep, its the same as the one in photo posted by John - it is for a cat equipped car, although I'm sure it could be adapted for a non cat car. I decatted my car a few years ago and used the normal non cat manifold. When I recatted the car for the new MOT, I refitted a crossover type manifold and didn't really notice any drop in power. The crossover manifold is much more efficient I think and made up for the losses from the cat.
It may take me a while to remove it, but if you're interested Johnboy, I'll give you first refusal...
johnboy
PostPosted: Wed Jan 16, 2008 12:13 am    Post subject: Reply with quote
Thanks rich
john
PostPosted: Wed Jan 16, 2008 8:38 pm    Post subject: Reply with quote
YEAH!!!!! You finally got it!!! Laughing Im happy for you and if my car was working i would order one today, alas.
When you said you ordered it directly from csc, did you do it online?? or do they have a distributor in the uk or did you call italy?
rsfruitbat
PostPosted: Thu Jan 17, 2008 8:42 am    Post subject: Reply with quote
Hi Rich B
Your new manifold looks the dogs dangly bits Very Happy Cool . Someone else has mentioned that the problem with the old ANSA manifold was how much ground clearance was lost. Can you tell if your new manifold is the same depth as a standard one or if its deeper, by how much?
Do you know what the power is before you fit the manifold and are you going to get it checked after? What improvements do they claim?
Regards rsfruitbat
bobbber
PostPosted: Thu Jan 17, 2008 10:27 am    Post subject: Reply with quote
On my 8v I had the straight configuration, and then later I had the "crossover" one too. I will state these were both original Alfa exhausts though (none of your fancy stuff!)
Some points I noticed :
1. The straight seemed to have decent power through the range, whereas the crossoever wasn't generally as good apart from at 4,000rpm (ish) where it was much better. I think this is to do with the variable tuned lengths in the straight which handles all rpm decently. In the crossover, due to it's equidistant design it was tuned more to one frequency and therefore just some rev ranges.
2. Much of the unique "boxer" sound seemed lost with the crossover - I remember it sounding completely undistinct.
HOWEVER, like I said, this was just a standard exhaust setup on an 8valve and it wasn't a patch on that work of art you've got there Rich!
Edit : I'm a little confused now actually, as I thought my crossover looked like the one John_33_16v has in his photo but thought that it was equal length pipes which the photo clearly isn't. Just going for a lie down.
Bob
Fiat Bravo 165 Sport
Rich B
PostPosted: Tue Jan 22, 2008 8:32 pm    Post subject: Reply with quote
Al - I ordered the manifold from CSC by contacting them via the "contact us" part of the website (www.csc-marmitte.it) but if you want the email address of the sales department, its office@csc-marmitte.it - the lady is called Veronica and couldn't be more helpful.
Bobbber, thanks for your comments, I found with standard non cat manifold and (VERY loud) OMP centre box, the power was all top end, on the motorway, acceleration from 80-120mph was very good (not so good on the ears though!). When I recatted and put on a normal cat manifold, I found there was a bit more torque low down although I'm not sure how much of this was down to the removal of the group N centre box or the crossover manifold. I didn't find the lovely boxer sound was any different with either type of manifold, just louder with the OMP system!!
rsfruitat - not sure about ground clearance, doesn't look like it'll be a problem, in fact I think the standard crossover manifold projects a bit more anyway, particularly the pipe that goes to the left front cylinder. Don't think I'm gonna do before and after power runs as my engine won't be running until its rebuilt and then it won't be standard, it'll have flowed heads and posh cams, maybe a bit more capacity and a change of ECU....
1994 33 16v
johnboy
PostPosted: Tue Jan 22, 2008 8:43 pm    Post subject: Reply with quote
Hi rich
can you post photo's of your manifold your selling as i want to see which type it is.as there are different types of crossover.
regards john
bobbber
PostPosted: Tue Jan 22, 2008 8:57 pm    Post subject: Reply with quote
Talking about exhausts.... I was under 'er the weekend.
Nasty old dirty exhaust under there! Wiped some of the dirt off... saw my reflection!
RESULT! Powerflow Stainless on there! Very Happy
Bob Cool
PostPosted: Tue Jan 22, 2008 9:11 pm    Post subject: Reply with quote
Jammie Beggar Smile
Rich B
PostPosted: Wed Jan 23, 2008 3:52 pm    Post subject: Reply with quote
johnboy wrote:
Hi rich
regards john
its exactly the same as the picture john 33_16v posted - its for a 16v cat car and has a flange at the point where it joins the centre box. Don't get too excited though, it'll be a while before I can remove it....
1994 33 16v
PostPosted: Wed Jan 23, 2008 6:31 pm    Post subject: Reply with quote
That was a shock in itself Laughing
johnboy
PostPosted: Wed Jan 23, 2008 8:12 pm    Post subject: Reply with quote
Laughing Laughing
Hi guy's
Rich ok chap Wink
your manifold is called the unequal length crossover manifold
regards john.
bobbber
PostPosted: Wed Jan 23, 2008 10:52 pm    Post subject: Reply with quote
You're right!!!! I thought someone had put a photo of George Clooney on my exhaust to start with! Laughing
Rich B
PostPosted: Thu Jan 24, 2008 12:19 am    Post subject: Reply with quote
being a flash sod, I've treated myself to a nice manifold for my 145 too (its a Supersprint in stainless steel and very nice it is too!!)....
yours smugly
Rich
1994 33 16v
PostPosted: Thu Jan 24, 2008 2:01 pm    Post subject: Reply with quote
Very nice.
Having had 145 clover with supersprint from cat back, i can heartedly recommend these:
http://www.diymonkey.co.uk/product.php?ASIN=B000UQDPBU
Rich B
PostPosted: Thu Jan 24, 2008 8:22 pm    Post subject: Reply with quote
john 33_16v wrote:
Very nice.
Thanks John!! I've already got Supersprint cat back system and I don't find it too bad at all. If you want loud try an OMP group N system on a 33, that makes your ears ring after a long trip!!!!
1994 33 16v
PostPosted: Sat Jan 26, 2008 8:22 pm    Post subject: Reply with quote
Thanks Rich B, sorry its been a while since i replied, im feeling a little sad not having a working car. How much was it? I cant for looking see on their web site, it used to be there im sure.
Rich B
PostPosted: Sun Jan 27, 2008 1:12 pm    Post subject: Reply with quote
Al - I mentioned it in an earlier post, it was 450 euros (approx £350) including delivery. A little more expensive than a certain supplier but at least I actually got it!!! Finally got a cheque the other day after threatening legal action
1994 33 16v
Goto page 1, 2  Next
Page 1 of 2
