16v engine stabiliser
PostPosted: Sun Apr 27, 2008 12:37 pm    Post subject: 16v engine stabiliser Reply with quote
Hello again:) preparing for my head removal I removed my engine stabiliser knowing that it is also fookd and needs replacing, as the middle part comes away from the bush.
Is the bush sold seperatly or is it sold as complete stabiliser? I have never replaced one on a 16v before.
gritsop
PostPosted: Sun Apr 27, 2008 3:39 pm    Post subject: Reply with quote
The side engine mount (stabilizer bar) is sold as a complete unit. The rubber bush is not pressed in but it is formed in the bar during production.
Thanassis Gritsopoulos
PostPosted: Sun Apr 27, 2008 5:26 pm    Post subject: Reply with quote
thanks for that bud.
PostPosted: Tue Oct 26, 2010 9:01 pm    Post subject: Reply with quote
I was originally thinking of getting my engineer guy to press out the ser 3 bush and make something to accomodate the locating part for the actual bar.
I was talking to Shrew about this and he thought of using another stabiliser on the other side.
I was thinking 2 ser 2 stabilisers could be used, the forces would be halfed and would not need to be as beefy as a ser 3, could someone post a picture of the way the ser 2 is attached to the block, as I cant remember and I will post a pic of the whole ser 3.
I am wondering if the ser 2 would work on the ser 3.
I can see a pic in bobbers post here
http://www.alfa-pages.co.uk/viewtopic.php?t=5472&highlight=stabiliser
anyone got any measurements?
PostPosted: Wed Oct 27, 2010 11:16 am    Post subject: Reply with quote
As an aside, not sure it is necessary. The Minaris used to omit that bar.
PostPosted: Wed Oct 27, 2010 12:56 pm    Post subject: Reply with quote
Have a read of the other thread RE what happens to other stuff when it fails http://www.alfaowner.com/Forum/alfa-33-sud-and-sprint/219529-engine-steady-bar-bush.html
PostPosted: Wed Oct 27, 2010 3:19 pm    Post subject: Reply with quote
Issue seems to be one person managed to get an exhaust issue with it
As to your idea of using a 2nd one on the other side. Not sure this would work. Being a small skinny bar I assume it works by being under tension, and on the other side it would probably be under compression in the same position with the bar likely easily bending.
PostPosted: Wed Oct 27, 2010 5:33 pm    Post subject: Reply with quote
Surely there's not that much force on it, my thinking was that when the engine twists in one direction it would pull on one side and compress the bushes on the other side and vice versa
33bits
PostPosted: Wed Oct 27, 2010 5:42 pm    Post subject: Reply with quote
A friend of mine has a 33 track car & he has fitted a 2nd bar. He seems to think it "slightly" helps eliminate engine movement under acceleration & is there as a back up in case the original 1 breaks.
He has had it there for about 2 years now, no probs yet.
155 sportpack
PostPosted: Wed Oct 27, 2010 5:48 pm    Post subject: Reply with quote
cool, thats good to know, I think the ser 3 ones are no longer available, the ser 2's are just rubber bushes so should be easier to replace.
PostPosted: Wed Apr 13, 2011 2:25 pm    Post subject: Reply with quote
Can the whole thing from a ser 2 fit a ser 3 16v
Oggie
PostPosted: Wed Apr 13, 2011 7:03 pm    Post subject: Reply with quote
It was me who had the rubber go and twist and snap my stainless steel manifold 2 inches after the flange on port no 4 I think, bear in mind if it wasn't needed it wouldn't be there, if like me you are sticking 75% more power from the engine things are bound to be more stressed therefore nessesary to be in good shape. I know after the hassle of repairing the exhaust its not worth neglecting a small cheap rubber bush.
PHAT 33
PostPosted: Wed Apr 13, 2011 7:19 pm    Post subject: Reply with quote
I agree Iain, I need to get mine replaced
