Posted: Thu Apr 02, 2009 5:32 pm Post subject: front anti-roll bar bushes |
Hey guys, i have just ordered new superflex bushes for the front anti roll bar on my 16v and just wanted to confirm i have orderd the correct ones.
http://www.superflex.co.uk/results.php?maker=7&man_name=Alfa+Romeo&searchmodel=64&Search=Go
i orderd
SPF1421/18 18mm Front Anti Roll Bar End Bush, non-stepped down version
SPF1420/18 18mm Front Anti Roll Bar Inner Bush, 33 only
I didnt order
SPF0241/14 102404 Front Anti Roll Bar End Bush, stepped down to 14mm, 33 only
as i dont think the anti roll bar steps down, have i got it right?
Thanks Alan _________________ x2 33 16v
Posted: Fri Apr 03, 2009 12:59 am Post subject: |
Thank you Than,
I was a bit concerned when it said 33 only, should get to me for monday.
Are they easy to fit?? _________________ x2 33 16v
Posted: Sun Apr 26, 2009 10:39 pm Post subject: |
I was a little worried when I went to change them as the 2nd ones down "SPF1420/18 18mm Front Anti Roll Bar Inner Bush, 33 only" looked to pointy in comparison to what was there. I almost didn’t take them off thinking they were incorrect.
Weird thing is that the rear "outer ones" had clear jelly like lube, whilst the front "inner" had white grease like lubricant.
The most time consuming part was removing the rust with a wire brush, I ended up slipping and putting the brush under my thumb nail, I also slipped with the ratchet and gave myself a black nail, DOH!
I didn’t know which way round to fit the splits in the bushes. At the front or at the rear, so I did one side one way and the other side the other way, I will check in a week to see if there is any settling.
One side didn’t sit very well, I will check in a couple of days.
All in all quite an easy job. _________________ x2 33 16v
Posted: Wed Apr 29, 2009 1:17 am Post subject: |
Should there be any difference in turn in after fitting, as mine seems a little sharper? Or am I just imagining it? _________________ x2 33 16v
Posted: Wed Apr 29, 2009 12:14 pm Post subject: |
Probably pyschological Al. Doing stuff to your car always makes it feel better. I can notice a great increase in performance just washing my car |
