Kris Alfa Arna
Posted: Fri Apr 03, 2009 9:39 pm Post subject: Speed sensors issues ... need help! |
Hello guys! I have 33 with broken/not working(probably) speed sensor. English is some way difficult for me so i will try to explain it simply. There are three things that can be not functionally properly. First of them is the speed sensor that is in the gearbox. Second is the dashboard and the third is wire issues. I can obviously check the wire if only know how to disassemble the sensor from the wire. And where is the ground wire for the sensor? Here are some photos:
speed sensor out of gearbox
The bush for the speed at the dashboard
the dashboard itself
Posted: Fri Apr 03, 2009 9:51 pm Post subject: |
Hi Kriss,
Does the odometer work?
im guessing the speed needle doesn't move.
I once had a speedo that worked but the odometer got stuck.
I would try not to remove / replace the gearbox sender unnecessarily as they brake easy.
I would first check there is an output from the gearbox sender, by measuring it at the dashboard connector end, therefore eliminating the sender, i don't know what to expect, someone here should be able to advise you.
If that's ok i would dismantle the dial and lube up the gear from the motor, that worked for me. I also bent all the connectors on the blocks out, to make a tight connection and cleaned the console contacts with powerflux, this is used to prime copper piping for soldering and brings it back to original without sanding any away. _________________ x2 33 16v
Kris Alfa Arna
Posted: Fri Apr 03, 2009 9:59 pm Post subject: |
If odometer means the thing that counts miles and km ... it doesn't work too, but it is connected to the speed, when no speed is detected, it can't count mileage .. or i think so.
So, is it some way to remove the sensor from the wire to measure the wire/cable to the dashboard ?
Thanks anyway for the support buddy! _________________
eagle3 Alfa 33
Posted: Sat Apr 04, 2009 6:17 am Post subject: |
A faulty speedometer/odometer is fairly common on 33s. Apparently they can be repaired with a bit of soldering but I haven't tried it myself.
The speed sensor is probably ok. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Kris Alfa Arna
Posted: Sat Apr 04, 2009 11:18 am Post subject: |
Kris wrote: |
So, is it some way to remove the sensor from the wire to measure the wire/cable to the dashboard ? |
Posted: Sat Apr 04, 2009 4:34 pm Post subject: |
hey Kris.
I am going to fit my new dials today and try to permanently fit a T2 tester in the dash as well. If you want i could put my car on axle stands, run the engine in gear and see what comes out of the sensor, unless someone else can inform what is to be expected. _________________ x2 33 16v
Kris Alfa Arna
Posted: Sat Apr 04, 2009 10:47 pm Post subject: |
I use to believe that must be 0,5-0,7 and 5-12 volts ... but i will be thankful if you send me more info. Today i see what comes from the sensor - 0 volts with wheel spining ... maybe the dash board isn't the problem _________________
Kris Alfa Arna
Posted: Sun Apr 05, 2009 4:49 pm Post subject: |
What type is the sensor ? Hall sensor or ? _________________
Kris Alfa Arna
Posted: Wed Jun 03, 2009 12:30 pm Post subject: |
done ... it was old transistor in the speedo _________________
