Posted: Fri Jan 13, 2012 11:08 pm Post subject: 16v oil pump wanted |
Anyone got one? _________________ 155 sportpack
armoore Alfa Arna
Joined: 20 Jan 2012 Posts: 13 Location: Croydon, Surrey.
Posted: Fri Jan 20, 2012 3:54 pm Post subject: oil pump |
Are you still looking? I think I have one from a 16v engine I scavenged the crankshaft out of for my 8v, but it will need looking for! |
Posted: Sat Jan 21, 2012 1:55 pm Post subject: |
Hi, yes a friend of mine still needs 1, if you find it then please let me know, thank you muchly.  _________________ 155 sportpack
armoore Alfa Arna
Posted: Sat Jan 21, 2012 4:49 pm Post subject: |
Found it! Took all of 1 1/2 minutes as it was exactly where I thought it was. In fact it was with the one I took out of my 8V and replaced with new. They both look the same including the cam to drive the mechanical fuel pump which the 8V has but the 16V does not (I think). Only difference is the 16V pump is natural metal in colour and the 8V is oil coloured. Let me know what you want doing with the pump. |
armoore Alfa Arna
Posted: Sat Jan 21, 2012 5:05 pm Post subject: |
Email sent. |
armoore Alfa Arna
Posted: Sat Jan 21, 2012 7:13 pm Post subject: |
Checked on ePer and both gear heights are listed for 8V (30 and 33 mm). I'll see if there are parts numbers identifiable on the two I have. I'll do some measuring too. |
armoore Alfa Arna
Posted: Sat Jan 21, 2012 7:15 pm Post subject: |
BigAl, just looked at your 33 which has reg. starting F33, so does mine! |
armoore Alfa Arna
Posted: Sun Jan 22, 2012 9:48 am Post subject: |
Mine ends DGJ. Must have come from the same dealer (or close) I suppose. |
armoore Alfa Arna
Posted: Sun Jan 22, 2012 10:43 am Post subject: |
Found out the change-over year from 30 mm to 33 mm gears was 1989 and mine is 1988, however the pump I took from the 16V engine definitely is 33 mm and is the "brighter" of the two. So let me know if you want it and how to get it to you. |
Posted: Sun Jan 22, 2012 5:37 pm Post subject: |
armoore wrote: |
I have seen one other 33 ending dgt  _________________ x2 33 16v
