burgo90 Alfa Sprint
Posted: Fri Sep 19, 2003 5:25 pm Post subject: central locking |
for some reason wen i go to lock the car from drivers side on the front and rear drivers side doors lock its the same if i try and lock it from passenger door only the front and rear passenger doors lock as u can imagine this is very annoyin ne1 got ne ideas _________________ http://www.novaload.net/features/viewfeature.php?ref=881 |
Posted: Fri Oct 03, 2003 12:11 pm Post subject: |
Sounds as though it might be something to do with the relay or its connections behind the centre console.
Eddie |
ak8635 Alfasud
Posted: Fri Oct 03, 2003 12:13 pm Post subject: |
even more weird:
when i open the driver door to the full extent, the central lock kicks in and out and in and out..
if i close the door it stops! _________________ A112 |
Dave_NZ Alfasud
Joined: 13 Mar 2003 Posts: 56 Location: Amsterdam, NL
Posted: Fri Oct 03, 2003 2:44 pm Post subject: |
that will be due to exposed wires where the wires go from the door to the body. over time they wear out and when they touch the metal body they ground with the 12v required to activate the CL. I have this from time to time and will eventually fix it. EARTH, the cause of most Alfa electronics problems.
Dave _________________ Looking for a type 2 33QV in NL |
ak8635 Alfasud
Posted: Fri Oct 03, 2003 3:42 pm Post subject: |
cheers dave.. _________________ A112 |
