Posted: Sun Dec 18, 2011 11:02 pm Post subject: Direct replacement door speakers |
If anyone has the oval door speakers & would like better noises from them without having big "boy racer" style things glued to their door panels, then this may be for you . I've got lots of these 70w speakers that fit behind the original 33 grills, perfect fit! I've fitted them in my M-reg 33 & took some picies for you to see.
The standard Alfa ones are paper 20w jobies, these new ones are great. _________________ 155 sportpack
john 33_16v not logged Guest
Posted: Mon Dec 19, 2011 10:22 am Post subject: |
Cool, good tip.
How much posted?
John |
Posted: Mon Dec 19, 2011 3:34 pm Post subject: |
I'd probably try a pair at £10 posted. £12 posted on the 'bay.
Posted: Mon Dec 19, 2011 4:35 pm Post subject: |
John, if you do deside to get these I would suggest disconnecting the tweeter on them and using the original alfa ones in the doors or using both.
If you only use the ones in the new speakers you will loose clarity as the speaker location blocks direct to ear sound of the high frequencies.
The original alfa loom uses 2 x 5mm female spade connectors, you will need to make an adapter up for negative terminal on the new speakers. _________________ x2 33 16v
Ian M Green Cloverleaf
Posted: Mon Dec 19, 2011 5:16 pm Post subject: |
Will these fit in a series 2 Alex ? _________________ Presntly own
Red Abarth 500c |
Posted: Mon Dec 19, 2011 6:26 pm Post subject: |
| Ian M wrote: |
| Will these fit in a series 2 Alex ? |
If you cut new holes Ian and run longer wires from the lower dash location.
As Al said the higher the tweeter the more clarity you get especially listening to the radio. I fitted 2 Alpine 10cm 2 way speakers in the original dash location but with no box behind the speaker the sound is very flat.
You could fit series 3 door cards and handles (using handles from the rear doors so no holes from the electric door switches). Sound a pain but less than 2hrs work. _________________ PHAT 33 |
Posted: Mon Dec 19, 2011 11:21 pm Post subject: |
These speakers are £14.70 posted. I have sold 5 pairs so far & fitted them in both the front & rear doors on my M reg 33, sounds soooo much better.
Yes like Iain said they will fit in any 33 door witout hitting any glass or window motor but either cutting the door card or fitting s3 cards is the only way to fit into a s2 Ian.
For the price i think they are great, just nice to triple the sound quality & still keep the original 33 look as they fit behind the standard grills. _________________ 155 sportpack
Posted: Wed Dec 21, 2011 3:47 pm Post subject: |
Hi Alex, yes definitely interested. New stereo in my red 33 is too powerful for the standard speakers. Save me a pair and send me an invoice after Christmas? _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Wed Dec 21, 2011 4:37 pm Post subject: |
Ok Paul, 1 pair put asside for you, i just had to order another 3 pairs,  _________________ 155 sportpack
