bw Alfasud
Posted: Thu Jun 23, 2005 1:25 pm Post subject: WANTED: P4 Fuel Tank |
The tank on my P4 has started leaking
Anyone got one for sale please?
Or, failing that, does anyone know if it's possible to effect repair on these tanks? MOT is coming up soon. |
Posted: Tue Jun 28, 2005 4:30 pm Post subject: |
Incidentally, the difference between injection and non injection tanks is that the former has an extra top connection for the return fuel.
I replaced my injection tank with a non injection one, and simply connected the return fuel line to the breather line. _________________ Dick Flower, Nr. Carcassonne. '94 Trofeo 1.4 ie (F), '93 Imola 1.3/1.4 ie (now for breaking) (F), '91 1.7 ie (GB)(spare car), '86 Sprint 1.5 QV (F). '87 VW Syncro camper (F), '73 NSU Ro80 (F), '99 Fiat Seicento (F) |
bw Alfasud
Posted: Tue Jun 28, 2005 4:41 pm Post subject: |
Thanks for the info, I'll take a look (eBay barred at work, so will look later)
cheers,
Ben |
mt Alfa Sprint
Posted: Mon Jul 04, 2005 11:45 pm Post subject: |
| RFlower wrote: |
| I replaced my injection tank with a non injection one, and simply connected the return fuel line to the breather line. |
I think the P4 one is different to both of these though, if i remember correctly it's smaller because of the rear axle/diff. Someone correct me if i'm wrong though.
Hi BW btw  |
Posted: Tue Jul 05, 2005 1:45 pm Post subject: |
P4 is similar volume, but different in its shape. Normal ie 33 has its tank under rear passangers seat, while P4 has rear diff there, so P4 tank is more behind under boot, somewhat shorter but higher. _________________ Tino Vatavuk
Pipster Alfa Arna
Posted: Thu Jul 07, 2005 10:11 pm Post subject: |
| i have two tanks for P4, but i'm from Slovenia. |
Posted: Fri Jul 08, 2005 9:48 am Post subject: |
How much do you ask for one?
Where in Slovenia, I'm going in the mornning to Zagreb for 3-4 days.
Pipster Alfa Arna
Posted: Mon Jul 11, 2005 10:26 pm Post subject: |
100€
The tank is in good condition. If you need any other P4 specific part speak now or forever hold your peace cause she is going bye bye soon.
I can delivere parts to Bregana border cross, Krsko or Brezice on weekends. The car is in Ljubljana. |
Posted: Wed Jul 13, 2005 8:48 am Post subject: |
That is a bit pricy.
Well there is a tone of things I would like to have:
- red chasis (just in case)
- starter
- charger
- speedo
- propshafts with mounts
- driver mirror
- in case you have clima, complete system with wiring ....
I'm going today back to Split, but will pass through Slovenia in about 10 days. I will PMl you _________________ Tino Vatavuk
LDA Alfa 33
Posted: Fri Jul 15, 2005 3:12 pm Post subject: |
i fixed a fuel tank on a p4 with chemical metal. just take the tank out and strip off all the plastic paint off the bottom and file it to the metal.
then use chemical metal to fill the holes and leave to set for a day or 2. pain it before you put it back in and bingo.. working fuel tank. the fix has lasted for 18 months so far and still going strong.
