		markgp4 Alfa Sprint
				 Posted: Fri Oct 28, 2005 8:51 pm    Post subject:  |
				Hi Mr T,
Did you ever buy any ? i see no-one posted a reply
I have been looking for a way to get some Neg camber on my Q4 to kill some of that terrrible understeer ... _________________ make it go faster   |
		hugh jinjin Alfasud
				 Posted: Fri Oct 28, 2005 10:26 pm    Post subject: camber adjustment |
				these eccentric bolts only work if you can set them  to give the required camber and tighten them up with a NUT on the other end. With the 33 the strut bolts screw directly into the bearing carriers so these type of camber adjusters won't work. I hope I've explained this clearly enough but if you don't know what I mean let me know and I'll try again!
The racers adjust the camber by elongating 3 of the 4  lower mounting holes in the strut which lets the hub carrier  pivot on the 4th bolt, giving camber adjustment. This however is not a fit and forget mod as over time there is a bit of movement so its not really recomended for a road car unless you like constantly fiddling with your car rather than driving it! |
		markgp4 Alfa Sprint
				 Posted: Fri Oct 28, 2005 10:36 pm    Post subject:  |
				Perfect explanation   thanks Hugh.
I was more thinking of my 155Q4 as you may know they have a terrible understeer problem and yes the bolts on the strut go right through to a nut on other side. so it may be possible on that car
it is really a trackday car so it does mostly get fiddled with at least as much as it is driven.... _________________ make it go faster   |
				 Posted: Sat Oct 29, 2005 7:39 pm    Post subject:  |
just few week ago I bought used shock with spring just to notice what Hugh told you, you can't use them on 33   _________________ Tino Vatavuk
		Rees Cees Alfasud
				 Posted: Wed Nov 02, 2005 11:36 pm    Post subject:  |
				only this works for camber adjusment
		markgp4 Alfa Sprint
				 Posted: Fri Nov 04, 2005 8:37 pm    Post subject:  |
				thats a nice set-up Rees.
but it can only work with narrow id coil-over springs yes?
then it all gets very expensive doesnt it ?
				 Posted: Sat Nov 05, 2005 8:38 am    Post subject:  |
				hi,
there is a trick to get neg camber on 16V : these car are fitted with lower height springs than other 33s.
so if you fit shocks from a normal 33 on 16V springs you'll get negative camber.
handling is improved on dry roads but when it gets wet and slippery you better slow down if you want to stay on the road. and tires wear on the inner side, lasting less than 15000 miles.
		paddy granger Alfa Sprint
				 Posted: Sat Nov 05, 2005 10:50 am    Post subject:  |
				| Is this is same on any Alfa 33 (non-16v) if you have lowered springs and use normal shocks?  Do you then also get negative camber? |
				 Posted: Sat Nov 05, 2005 11:03 am    Post subject:  |
				hi,
yes if you lower the springs on any 33 you'll get negative camber. you can correct this by widening the upper drill at the lower end of the shock absorber ; when you reach proper adjustment position, drill a third hole through strut and steering knuckle and use a bolt to lock the assembly in position.
disclaimer: dear reader this mod can be dangerous, if you're not up to the task please have someone do it as any error may endanger your life as well as the life of other people.
		Rees Cees Alfasud
				 Posted: Sat Nov 05, 2005 12:08 pm    Post subject:  |
				@markgp4:
I never tried it with normal springs, but it schould work.
@paddy granger:
Thats true.
@ZeNiTh-PbArM:
Very dangarous don´t try this at home
As before mentiont a 33 has normal terrible understeer and the only way to change taht is give the car more negative camber.
2 options:
Lowering spings. but this will kil your shokabsorbers
or my option by making the upper mounting of the shokabsorber moveble.
there are in my opinion no other ways (I have more than 5 years experians with racing in a 33) |
		sportston Alfasud
  Joined: 15 Feb 2006 Posts: 87 Location: Lowestoft, suffolk
				 Posted: Wed Feb 15, 2006 11:52 pm    Post subject: drill it out! |
				The Cammed bolts are a great idea! why not just drill out the existing threads and put a new nut on? Thereby making it possible to adjust.   |
