micap Alfasud
Posted: Wed May 21, 2003 4:49 pm Post subject: Clutch change |
What's the exact procedure? What parts are needed besides a new clutch? Think I'll get a workshop to do the change, but any ideas how much time it should take so I have an idea of the cost? _________________ /Michael
ex 89 1.7 QV
Yvon Alfasud
Posted: Wed May 21, 2003 5:39 pm Post subject: |
What I do (a few hours ago !!) :
- remove engine from down
- disconnect the gearbox
- replace clutch, mecanism and bearing (I bought the full kit)
- remove the flywheel (hard to unlock the screw !!)
- replace the main end bushing
- check and replace slave cylinder
- replace the fork that was not anymore centered and worn abnormaly the slave cylinder
and reassemble everything.
I should say 8 hours job but it is just my opinion.
Ciao
Yvon |
Posted: Wed May 21, 2003 10:58 pm Post subject: |
replace also the pin that locates the fork |
Gary UK Alfa Sprint
Posted: Wed May 21, 2003 11:58 pm Post subject: |
To remone the flywheel bolts, bolt a nut and bolt through one of the securing holes in the bell housing and wedge a 'v' of metal (just bend a bit of 3mm flat bar)between the bolt and the teeth in the flywheel. Always use new flywheel bolts. ps don't catch it if it drops |
Yvon Alfasud
Posted: Thu May 22, 2003 6:12 am Post subject: |
I had a chance to use a pneumatic tool
Gary UK wrote: |
..... ps don't catch it if it drops |
What do you mean ?
Ciao
Yvon |
Posted: Thu May 22, 2003 6:39 am Post subject: |
Just a tip he found out. Stops you from crushing your fingers between the flywheel and the ground. _________________ Scott Sander
Sergio Alfa Sprint
Posted: Thu May 22, 2003 7:54 am Post subject: |
Does it really take 8 hours to replace the clutch on 16v???? I've got my replacement schedulded for monday and money isn't rolling in (become unemployed). I was told that it would take about 3.5 hours, maybe up to 5 hours max, to replace it. I really need to replace it because it's horrible to drive in heavy traffic (jumps alot), otherwise I wouldn't be wasting precious money.
all the best
Sérgio |
Yvon Alfasud
Posted: Thu May 22, 2003 8:06 am Post subject: |
Then I guess they would not take the engine out and that means they know how to do it with necessary tools (gearbox lift).
In that case, this is a realistic figure for well trained people with the correct tools.
Ciao,
Yvon |
Sergio Alfa Sprint
Posted: Thu May 22, 2003 9:22 am Post subject: |
I'm going to take it to the official Alfa-fiat-lancia workshop, so the must have the right equipment...
Sérgio |
micap Alfasud
Posted: Thu May 22, 2003 9:27 pm Post subject: |
So that's a clutch kit, a main end bearing, slave cylinder, fork and fork pin? It all sounds a bit too tricky for my mechanic skills, but as long as I now what is needed. _________________ /Michael
ex 89 1.7 QV
Ian M Green Cloverleaf
Posted: Thu May 22, 2003 11:06 pm Post subject: |
Five hours is about right to do clutch.
Can be done by just removing gearbox.
Any garage that knows what it is doing should take no longer than that. |
