ALFAPARTS Guest
Posted: Wed May 17, 2006 12:09 pm Post subject: w: P4 visco rubber mounts HELP””””””” |
hi guys:
my name is Enrique, I'am the owner of ALFA PARTS in Spain www.alfaparts-tuning.com , I have bought a Alfa 33 P4, and we were begening a big restauration and modify the car for a track days. Now we have a problem, we need the two silent blocks for the transmission, at both sides of the viscomatic. The number parts are 60505302 and 60572375, in spain is no more avalaible, if some one have a new one or used in good condition we are very glad to buy.
best Regards and Forza Alfa |
stedee Alfa 33
Posted: Wed May 17, 2006 7:34 pm Post subject: viscous coupling |
here in the uk you can get the same rubber joints from a driveshaft centre , just take the rubber joints with you and show them to the guy and he should be able to find some for alot cheaper than an alfa dealer
steve _________________ brum brum |
stedee Alfa 33
Posted: Thu May 18, 2006 6:00 pm Post subject: |
i dont know if you are saying he needs these ones not the ujs on the prop
but a mate of mine who used to work in a driftshaft centre reckons you can get them from there, other cars have the same set up apparently
Posted: Fri May 19, 2006 12:03 am Post subject: |
Yes you got me right, I was saying he needed suports not uvj.
Latter one can be still found because it is same part as on few 75 (even older Alfas), or even can be made.
But 1st mount which is all rubber with only metalic ends and middle bearing is imposible to find for last 2-3 years
If you could find replacement for it I'm sure many P4 owner around world would be thankfull for it, I know I would.
p.s. I was thinking of desingning that one myself and giving it to profesional who works with rubber . _________________ Tino Vatavuk
stedee Alfa 33
Posted: Fri May 19, 2006 6:35 pm Post subject: |
i will find out for you ,i live in the midlands of the uk which is an automotive hotspot, you can get most stuff here if you know where to go
i have got a p4 which i am breaking and i will take off the coupling (gearbox already off) and take it to this driveshaft place and see what they say, i will tell you what happens even if it makes me look like a fool
Posted: Fri May 19, 2006 9:20 pm Post subject: |
Hey Steedee... is that brum brum 'BRUM'? _________________ Fiat Bravo 165 Sport |
stedee Alfa 33
Posted: Sat May 20, 2006 9:02 pm Post subject: |
yeah well near enough - wolves _________________ brum brum |
