8v & 16v parts for sale
Goto page 1, 2  Next
PostPosted: Wed Jun 28, 2006 12:12 pm    Post subject: 8v & 16v parts for sale Reply with quote
8v K&N air filters, boxed with spare cork gaskets, 1 is cracked so I have 1 new
8v twin 40 webber carbs
8v boot catch new unused
8v n/s plastic trim for front headlight new not painted
8v complete big end kit new and boxed
16v n/s & o/s front fog light housings
16v pipe work for front light jet wash Inc 1 jet wash
16v throttle sensing switch
16v air box and filter
16v radiator
16v n/s font light
16v non cat mid exhaust section
16v front bumpers, red and silver
Twin horns red
2 petrol tank rubbers from tank to filler neck 1 is new
Hand break cable, new in packaging
stedee
PostPosted: Wed Jun 28, 2006 10:55 pm    Post subject: Reply with quote
i
hi i would be interested in some anti roll bar bushes if they are new
cheers steve
brum brum
PostPosted: Thu Jun 29, 2006 12:06 pm    Post subject: Reply with quote
sorry steedee, got all but those Crying or Very sad The ones i have are for trailing arms, panard and tie bar ect.
WILL ALSO HAVE COMPLETE 16V NON CAT EXHAUST SYSTEM SOON
stedee
PostPosted: Fri Jun 30, 2006 6:27 pm    Post subject: Reply with quote
cheers let me know when youve got it
brum brum
PostPosted: Sat Jul 01, 2006 1:59 pm    Post subject: Reply with quote
no probs, will be soon as mot needs to be done by the end of this month but i want to get it in asap. Havent found any doners fot the middle section so i will buy a new one Crying or Very sad so i will also have a repairable cat for sale aswell.
PostPosted: Sat Jul 01, 2006 3:30 pm    Post subject: Reply with quote
Hi Al, could you explain exactly what you are after. You're after a middle section, but should the front end be boltable or simply slip over the front manifold like the older versions. Are you after just the pipework or the actual baffle part?
PostPosted: Mon Jul 03, 2006 10:33 am    Post subject: Reply with quote
hi paul. Im after a 16v middle section, can be cat or non cat, i dont need the baffle/cat, just the pipework after the baffle/cat. Where the cat/baffle ends, to the end of the pipework where it joins onto the rear box.
This will then be cut off and the same pipework will be cut off my good working cat and replaced with what i have just cut off the good doner baffle/cat. Remeber at the alfa day i checked the size of the ie cat you had and found it to be to small?? Thats why i neeed a 16v middle section. Hope that makes sence Smile
PostPosted: Mon Jul 03, 2006 1:52 pm    Post subject: Reply with quote
I've got an old style 16v middle section that is buggered right by the baffle. No bolts at either end, just simple pipework. Confused Question
Ketil-no
PostPosted: Tue Jul 04, 2006 10:05 am    Post subject: Re: 8v & 16v parts for sale Reply with quote
8v fast road Kent cams fitted in ported heads
How much do you want for the above listed parts?
Regards Ketil
PostPosted: Thu Jul 06, 2006 11:44 am    Post subject: Reply with quote
Ketil-no
I dont know if you have seen my location, but im in the u.k. I have pm'd you
Paulhide
i have pm'd you 2 and sent you a txt and left a v/m
PostPosted: Thu Jul 06, 2006 3:33 pm    Post subject: Reply with quote
It seems that when I got somebody to take away a stripped car for the scrappy last month, they saw the broken exhaust and took that too. However I've got a good one you could have for a tenner.
PostPosted: Thu Jul 06, 2006 6:43 pm    Post subject: Reply with quote
sweet thanks paul, i already got your txt Smile
PostPosted: Thu Jul 13, 2006 12:50 pm    Post subject: Reply with quote
Stedee, just to let you know that the complete exhaust system is up for sale now
I got my cat on, yea, it seems a lot quieter Crying or Very sad need a louder backbox now
stedee
PostPosted: Thu Jul 13, 2006 8:41 pm    Post subject: Reply with quote
funny enough i have got a louder backbox on mine, it was there when i bought it, i dont want it i prefer the raspy sound rather than the deep sound so its yours if you want it.
also do you mean i can have the middle decat part because i didnt want to pay alot to be honest and i dont really need a full exhaust as i have got a decent front part and nearly new standard backbox
brum brum
PostPosted: Fri Jul 14, 2006 12:06 pm    Post subject: Reply with quote
Wanna swap then? Very Happy
stedee
PostPosted: Fri Jul 14, 2006 12:35 pm    Post subject: Reply with quote
sounds good to me!!
i will have to take it off and give it a look over make sure its ok but there was a sticker on the car saying it was stainless whether this is true or not i will tell you sunday(i would do it earlier but really really busy at work) Sad
steve
brum brum
PostPosted: Fri Jul 14, 2006 3:21 pm    Post subject: Reply with quote
Thanks, i will put off adjusting my backbox and using exhaust paste, as i forgot to take it with me when i fitted the cat and not got round to doing it since, due to being a bit busy myself
PostPosted: Mon Jul 31, 2006 1:19 am    Post subject: Reply with quote
heads now sold
1 fuel tank rubber now sold
PostPosted: Thu Sep 14, 2006 10:12 am    Post subject: Reply with quote
bump
just to remind you people
8v fast road Kent cams fitted in ported heads now sold
16v second hand radiator (corroded bottom part) put back on old car
16v non cat manifold put back on old car
16v rear exhaust box put back on old car
Sprintervention
PostPosted: Sat Oct 07, 2006 6:13 pm    Post subject: Reply with quote
are the big end bearings standard size or oversize?
May be interested....
Chris
1987 Alfa Sprint Veloce
PostPosted: Mon Oct 09, 2006 5:15 pm    Post subject: Reply with quote
i orderd big complete bearing kit for 1.7 8v. i will post part numbers when i can
Sprintervention
PostPosted: Mon Oct 09, 2006 5:46 pm    Post subject: Reply with quote
Chris
lxb
PostPosted: Sat Oct 21, 2006 5:48 pm    Post subject: Header tank?! Reply with quote
Hey BigAl.... I'm in Surrey too (Purley), is there a good local club worth joining? I'm suddenly, and desperately, on the hunt for a radiator header tank - the plastic on mine has developed fissures, allowing the water to escape under pressure!
Ta.
Alex
K737 MMM... my slightly dog-eared but willing 33 1.7ie 8V. Awwww.
PostPosted: Mon Oct 23, 2006 9:55 am    Post subject: Reply with quote
Sprintervention (chris), sorry not had a chance to look for part numbers.
LXB (Alax), clubs in surrey, hmm I used to goto a pub on reigate hill, back in the day. This got moved to a pub on the a22 after redhill and before godstone, its right near a speed camera. RE: headertank, your prob best speaking to alfa dave peters, hes the chairman for the 33 club and has lots of spare parts. Other prople you could try are;
bianco auto development 01293 821843, MD Autos 01293863853, both near gatwick and there is 1 more but he seems to be out of business at the mo and its Rusper alfa 01293 871155
lxb
PostPosted: Mon Oct 23, 2006 11:43 pm    Post subject: Ta Reply with quote
Cheers BigAl - might look up that pub on the a22. Smile
Goto page 1, 2  Next
Page 1 of 2
