Posted: Wed Dec 26, 2007 8:10 am Post subject: how i spent the weekend |
Posted: Wed Dec 26, 2007 10:09 pm Post subject: |
yep, new bearings, new rings, cylinder bore honing, valve lapping, new seals, new belts & tensioners. despite 600,000kms of good service, pistons, valves, guides, tappets, camshafts were found to be within specs and were thus not replaced.
Posted: Thu Dec 27, 2007 7:14 pm Post subject: |
Good job.
I wasn't brave enough to take my block indoors on the kitchen sink!!! |
Posted: Thu Dec 27, 2007 7:25 pm Post subject: |
| lee16v wrote: |
Good job.
My sink / worktop wouldn't take the weight, plus the mrs would have a fit.
Good job!
Call me Kittens (he he, i wrote a n a l here- i've never got a replacement word to come up on a forum before!), but, that power socket next to the sink is a bit of a worry
Posted: Thu Dec 27, 2007 8:09 pm Post subject: |
Well, the problem is, ain't no sink in my workshop. Ain't no water, ain't no electricity, no light, no heating, no space...
Posted: Fri Dec 28, 2007 1:01 am Post subject: |
Hi ZP,
As you may have correctly guessed, Alfa people like pictures ...
So more pictures from the rebuilt are always welcome
Posted: Fri Dec 28, 2007 9:01 am Post subject: |
No way, 600,000kms and your camshafts and tappets were within spec? Mine were wasted at less than quarter of that mileage.
How did you remove the block from the car? _________________ "Now, all that is left to do ... is wait that something else brokens, to fix up again!" |
Posted: Fri Dec 28, 2007 11:38 am Post subject: |
Great job chap,shame about lack of space 600,000km just shows,alfa should have shuck with the boxer.just made it bigger
Posted: Fri Dec 28, 2007 8:47 pm Post subject: |
the block was removed from the car using a false wooden sump, flat, and an hydraulic jack. During refitting, engine was lifted and installed by hand, which means i was sitting under the hood and lifting the short block with my arms. Quite an easy job, but then i had to fiddle to get the gearbox axle straight in the clutch. Well, due to the reasonable weight of the block, i didn't suffer too much from it.
Concerning cams & tappets, all of my pals always laughed at my frequent (5000kms) oil changes, and filter every second oil change. I use semi-synthetic 10W40 oil, mostly Mobil Super S over the last 400 000 kms. Besides, i always let the engine idle a full 2 minutes when starting from cold. I also hear some oil filters lack an oil relief valve which prevents oil starvation during cold starts ; i always use Purflux LS515 or original Alfa cartridges.
Here's a few more pics.
zp
Posted: Sat Dec 29, 2007 10:19 am Post subject: |
Yours:
Mine:
Yours:
Mine:
These are photos of the worst lobe and second worst lifter from the engine of mine that broke a cambelt.
I'm a good boy with my oil changes, but the problem is I can't buy an Alfa with an engine that's in good condition to start with! My current engine makes lots of clattering and I expect it has the same problem as the photos above.  _________________ "Now, all that is left to do ... is wait that something else brokens, to fix up again!" |
Posted: Mon Jan 07, 2008 11:53 pm Post subject: |
Yep yours are worn! i recollect changing tappets on a customer's 145 last winter. Exhaust valve on cylinder #2 would never open, hence the car was running on 3 cylinders while compression test, ignition & injection were OK.
After head removal, i found one dead tappet, two worn ones, and one good on this cylinder bank. Camshaft was worn on three lobes, and tappet bores were worn to the point that clearance was far out of spec even with new tappets. Customer didn't want to change all the stuff so only tappets wrere replaced. Guess what? The fix only lasted six months...wear caused clearances to increase dramatically and the engine was no more able to sustain oil pressure at idle, and bad knocking sound could be heard from said camshaft housing.
I heard this failure is quite common on 145/146 boxer models ; our local Alfa shop said it had seen several and suspected Alfa reduced quality or hardening of tappets on those cars.
zp
ps : i had to dig up the old tappets from the 145 but had kept them in my gar(b)age :
Posted: Mon Jan 07, 2008 11:59 pm Post subject: |
Zenith,
Out of curiosity... What do you do for a living ? Are you an engineer, electronics guy or simply an enthusiast dealing with Alfas
Posted: Tue Jan 08, 2008 11:59 pm Post subject: |
In a former life, i used to repair cars for a livin, but well, no more! Today i still fix some from time to time, mostly tricky problems or exotic developments, between two regular jobs. Desperately trying to get a job that'll let me enough spare time to enjoy another of my hobbies : mountain climbing.
Posted: Wed Jan 09, 2008 11:12 am Post subject: |
| Quote: |
| After head removal, i found one dead tappet, two worn ones, and one good on this cylinder bank. Camshaft was worn on three lobes.. |
Strange how they wear so unevenly! The cam in my photo above has lobes and tappets which look almost OK, and yet also has that mangled lobe. At least it didn't wear all the way through the tappet like those from that 145. Now I understand why tappets can't be 'reconditioned' by grinding down the wear surface until it's flat again!
| Quote: |
| and tappet bores were worn to the point that clearance was far out of spec even with new tappets. |
Don't tell me tappet bores can wear, I don't want to hear that!
If that's happened what am I gonna do, buy new heads from Alfa?  _________________ "Now, all that is left to do ... is wait that something else brokens, to fix up again!" |
Posted: Wed Jan 09, 2008 11:04 pm Post subject: |
Since the worst wear always appear on cylinder #2, which is the farthest from the oil pump, it might be possible to incriminate oil starvation due to insufficient flow when engine's cold. Oil filters without bypass valve are reported to trigger such problems.
And yes, cam bores wear! On the Alfa Nord engines, tappets bores were bored directly in the head. Due to the cost of a new head, Alfa supplied oversize tappets (no more available today) ; in case of wear, it was possible to re-bore the head and install bigger tappets to restore proper clearance. Sud engines tappet bores are part of the "cheap" camshaft housings ; replacement of the housings is required whenever clearances get out of specs.
In my experience, tappet bores easily get oval, and in the case of chewed tappets & camshafts, they're almost all the time damaged beyond repair. The easiest solution is to find good second-hand ones. New tappets can be sourced at various dealers, including Audi, Rover, Ford, Seat, Opel and Volvo ; maybe some of these manufacturers also sell oversize tappets, i never really inquired. Anyway it's still possible to refurbish an old housing by inserting custom-made liners. Not a cheap solution, unless you're friends with a local machine shop...
zp
