etj987 Alfa Arna
Posted: Fri Apr 11, 2008 7:51 pm Post subject: Alfa 33 not starting |
My Alfa 33 does not start. There is spark on all sparkplugs but it seems very week, small and yellow, not fat and blue.
There seems to be fuel coming through as the catalysator started burning after a long attempt to start it. It started running on 2 cylinders but never more.
Anybody out there who has any idea where to start and how to eliminate sources of fault.  _________________ Alfa 33 1,7IE 1992 |
Posted: Fri Apr 11, 2008 8:27 pm Post subject: |
Have you taken the distributor cap of or replaced the ht leads at all?. If not I would check the condition of the cap to see its not cracked and the rotor arm (inside the cap) is not dirty. failing that the coil lead to the coil might need swapping out. Also check your earth leads both to the chasis and to the starter motor as I have had silly issues with this, I hope this helps and good luck. _________________ PHAT 33 |
Posted: Fri Apr 11, 2008 9:15 pm Post subject: |
Have you definitely got the leads going to the right plugs - I once stupidly thought I knew where they went. I had got the right order, but was actually 90 degrees out. The engine kept catching, but wouldn't start, till I realised what I'd done. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
etj987 Alfa Arna
Posted: Sat Apr 12, 2008 1:58 am Post subject: Alfa 33 not starting |
Sparkplugs, cables, distributorcap and the rotorarm are all replaced a month ago and I have checked that the cables are in the correct positions.
No. 1 front right, no.2 front left, no.3 back right, no. 4 back left. fiering order 1, 3, 2, 4. No 1. on the distributor same as no1. cylinder, front right. _________________ Alfa 33 1,7IE 1992 |
