How to clean the header tank?
PostPosted: Thu Jun 26, 2008 11:55 pm    Post subject: How to clean the header tank? Reply with quote
I am going to put a 16v header tank with the plastic screw top on, as I replaced my leaking one with a metal twist cap one.
It is a little dirty inside, last time I cleaned one of these I used sand and water. There are compartments that a brush won’t get to. I shook it vigorously and rinsed out thoroughly. This time I was thinking of doing the same and using gunk.
Anyone got any other ideas?
RBL
PostPosted: Fri Jun 27, 2008 10:16 am    Post subject: Reply with quote
Maybe caustic soda or bleach?
Porsche 550 spyder replica with Alfa Sprint 1.7 engine
RFlower
PostPosted: Fri Jun 27, 2008 11:13 am    Post subject: Reply with quote
Sand and water will make the interior surface rough and more likely to encourage deposits, and is difficult to get out again because of the baffles inside.
I use a product named FERRONET, which I bought in Spain.
http://www.nautilus21.com/catalog/product_info.php?products_id=448
I don't know if there is an equivalent in UK. It is sold for cleaning iron and steel, also for removing lime incrustation on sanitary ware etc. It is acidic, maybe hydrochloric, more likely a mixture.
Mixed about 1:2 with water and left inside with the outlets plugged, turning around occasionally to coat all the surfaces, it completely removes rust and other deposits, and even dissolved the small loose pieces of rust which I couldn't wash out.
PostPosted: Fri Jun 27, 2008 12:27 pm    Post subject: Reply with quote
One thing worth trying if it is oily dirt is to soak it in biological washing powder.
PostPosted: Fri Jun 27, 2008 8:27 pm    Post subject: Reply with quote
Didn't think the sand would do that, good to know, wont do it again, last time I did it, I took my time making sure it was all rinsed out, did a really good job though and when i drained out my coolant, it was clear blue. I only have toilet duck “lime scale remover” to hand at the moment, which is being left over night until I get something else.
It’s the usual calcium / scale deposits coating the inside, cant believe how much crud came out.
Off to rotate header tank againg Laughing
ZeNiTh-PbArM
PostPosted: Sat Jun 28, 2008 11:07 am    Post subject: Reply with quote
Hi, i use salt and shake the tank until all of the crud has been removed. After this, I empty the tank and flush it with tap water until i'm sure all of the salt has dissolved. I wouldn't want to try with sand, because you're never sure no grain is left after cleaning, with salt you're sure! and it's cheap and harmless, and works a treat on rusty deposits.
zp
PostPosted: Sat Jun 28, 2008 6:08 pm    Post subject: Reply with quote
sweet Smile thanks, or should i say salty Laughing
PostPosted: Sun Jun 29, 2008 5:51 pm    Post subject: Reply with quote
I managed to get it fairly clean, using toilet duck and leaving over night. There are just a few bits left, so I rinsed it out and added some salt. I think I need one of these vibrating thingy’s as it doesn’t seem to be doing anything.
suds
PostPosted: Mon Jun 30, 2008 10:14 pm    Post subject: Reply with quote
I have used cheap cola lefted over night ciao daz Laughing
romance of rust
alfasud 1.5 ti
alfasud super 1.3
Alfa 155 2.0ltr 8v
Fiat croma 1.9jtd
PostPosted: Tue Jul 01, 2008 8:07 am    Post subject: Reply with quote
dont you mean pepsi??? Laughing
