P4 Paul Alfa Sprint
Posted: Sat Aug 02, 2003 8:49 pm Post subject: sports exhausts?? |
| anybody out there know of any decent sports exhausts available for a 33 1.7 16v p4? |
Posted: Sun Aug 03, 2003 12:12 pm Post subject: Re: sports exhausts?? |
| P4 Paul wrote: |
Hi paul,
my 16v conversion has an OMP group N sport's system which will give you more torque.check out demon tweek's mag.there £116.71 +vat and they say you mite have to adjust the air-fuel mixture to get the best out of it.hope that help's john _________________ WODA WE NEED? MORE POWER!!
Mixsynth Alfa Sprint
Posted: Sun Aug 03, 2003 12:21 pm Post subject: |
Just a quick off topic question John - you describe your 16V Veloce as a "G90" - what does this mean? _________________ Hugh B
'98 145 QV
Posted: Sun Aug 03, 2003 12:32 pm Post subject: |
| Mixsynth wrote: |
| Just a quick off topic question John - you describe your 16V Veloce as a "G90" - what does this mean? |
Hi hugh
from take off it pull's 90 G's.no it's just the reg p.s got the engine apart,bent all 8 valve's one side,quite imprest with that.most people do a couple, got hold of another head,get it monday. john _________________ WODA WE NEED? MORE POWER!!
P4 Paul Alfa Sprint
Posted: Sun Aug 03, 2003 9:58 pm Post subject: omp exhaust |
| would that be a full system,or just the back box? |
Sergio Alfa Sprint
Posted: Sun Aug 03, 2003 10:48 pm Post subject: Re: sports exhausts?? |
| johnboy wrote: |
| P4 Paul wrote: |
Hi paul,
my 16v conversion has an OMP group N sport's system which will give you more torque.check out demon tweek's mag.there £116.71 +vat and they say you mite have to adjust the air-fuel mixture to get the best out of it.hope that help's john |
What does this system sound like?
Is it the VERY VERY LOUD type or sporty tone like?
Sérgio |
Posted: Sun Aug 03, 2003 11:07 pm Post subject: |
D HI ,does anybody have specs of pipe dia and lengths for 2into1,2into1type extractor to suit a 1500. I want to make my own.
Regards Eddie |
alferr Alfasud
Posted: Mon Aug 04, 2003 12:29 am Post subject: |
i think ANSA make proper engine heards, with a crossover pipe!! worth getting this if you are changing you exhaust!,
I run 2 1/4 inch off the headers! _________________ -=alferr=-
goto #alfa33_net on DALnet |
Posted: Mon Aug 04, 2003 3:20 am Post subject: |
Thanks but i have made afew headers in the past and fancy making my own for the ever present budget reasonsI used to use a Piper formula where the length was worked out on cam timing to place peak torque where you wanted it and the dia was to give twice the swept volume of a cylinder within this length. I thought somebody might have the figures and save my poor old brainbox from having to work it out . The 33 would be one of the easiest cars to fabricate on if you have access to a hoist which i have. I believe that reasonable gains can be had with a proper crossover system as the standard setup is more of a freeflow and doesnt use the firing order to extract.
Eddie
1986 33 1500
1987 33 1500
1990 33 cloverleaf |
Posted: Mon Aug 04, 2003 3:19 pm Post subject: Re: omp exhaust |
| P4 Paul wrote: |
it's the hole system,as for the sound i'll let you know when i weild it up,as it came off the doner car and was hit on the tail pipe and is broken at the s bend.but sound's good as it is,but the law won't like it  _________________ WODA WE NEED? MORE POWER!!
P4 Paul Alfa Sprint
Posted: Thu Aug 07, 2003 2:07 pm Post subject: omp exhaust |
just got one of them omp exhausts,it will not fit as the exhaust on a 33 p4 is sooooo totally totally different!!!!!so now its being sent back.
Anybody else got any bright ideas???  |
Posted: Thu Aug 07, 2003 3:15 pm Post subject: Re: omp exhaust |
| P4 Paul wrote: |
Hi, not good about that,is it because of the 4-wheel drive system is in the way? because mine came off a j-reg series 3 16v,what's the difference apart from the drive chain.sorry about that, thought they where the same  |
Maximilian Alfasud
Posted: Thu Aug 07, 2003 5:22 pm Post subject: |
Guest,
Where did you get the exhaust from.
I'm always looking for a second hand performance backbox, but can never find any.
I've got a nearly new standard system, so I can't justify buying a new one. _________________ 1988 Sprint 1.7 QV (35,000 miles) |
Posted: Thu Aug 07, 2003 7:40 pm Post subject: |
[quote="Maximilian"]Guest,
Hi maximilian,it came with the 16v car i broke for the conversion i did on my series 2 clover.checkout demon tweak's mag ok
cheer's john _________________ WODA WE NEED? MORE POWER!!
