| Price |
| £150 - £200 |
80% |
[ 4 ] |
| £250 - £300 |
20% |
[ 1 ] |
| £300 - £350 |
0% |
[ 0 ] |
| Total Votes : 5 |
Posted: Mon May 10, 2010 8:51 pm Post subject: Veloce bumpers |
What interest is out there for Veloce bumpers?
What price would you pay for new?
Any interest for Veloce bumpers made to fit the ser 3 with the dip in the middle for the grill between the lights? _________________ x2 33 16v
Posted: Tue May 11, 2010 10:57 pm Post subject: |
Hi Alan, i think they are deff the best choice for a s2 33. If i had a s2 then i would most deff want the Veloce bumpers & skirts for it. Are you thinking of fitting some on your car? _________________ 155 sportpack
Posted: Wed May 12, 2010 2:58 am Post subject: |
Yup, I sure am. I know a fibreglass specialist who will copy the originals and make moulds to make more.
I plan on having mine modified so it will fit on the ser 3.
I guess no one else is interested.
It won't be for a while, I have to source some to borrow, the donor ones may need to be fixed if not perfect. _________________ x2 33 16v
Posted: Wed May 12, 2010 6:48 pm Post subject: |
Give Paul a ring. About 18mths ago i bought 3 new Veloce bumpers (1 front, 2 rears), off him. I forget who he got them from but they were perfect. 1 of the rear ones turned out to be for a sportwagon and they all came with new metal bars & brackets too. I may have a spare front Veloce bumper you are welcome to if needed, i'll have a look. _________________ 155 sportpack
Posted: Wed May 12, 2010 7:01 pm Post subject: |
Thanks.
The purpose of this thread was to find out if anyone is interested and how much they would pay for new bumpers, the more the cheaper.
Looks like i will just get them copied for myself.
I am surprised that no one has shown any interest, I think the Veloce bumpers look the nuts and when i owned a ser 2 i had the last front bumpers made as the original alfa moulds were thrown away, all 60 of them, i tried to find out who/where they were and why the moulds just couldn't be re-used. They were hard enough to get hold of then, now they must be near impossible. _________________ x2 33 16v
Posted: Wed May 12, 2010 7:23 pm Post subject: |
Hi Al, bet making a one off will not be cheap, why don't you try Ahm as adie does a 75 veloce bumper kit to fit the s3 33.
http://www.ahmotorsports.co.uk/index2.htm
AHM RACE ALFA 33 front bumper
AHM splitter carbon or f/glass
Bumper
Carbon
£450.00
Fibreglass
£350.00
splitter
£150 Carbon
£100
Fibreglass
AHM RACE MK 3 Bonnet carbon
BONNET HAS TO BE MOUNTED WITH PINS
Bonnet
Fibreglass £180.00
Carbon
£230.00
AHM RACE AIR BOX in carbon
POA
AHM RACE MK3 33 boot lid in carbon or f/glass
This boot lid has fixings for std hinges and catch if used for std cars
Carbon
£200.00
Fibreglass
£150.00
PART NUMBER
DESCRIPTION
PHOTO (click for larger image)
PRICE
V6 Engine Parts
GTV6 , SZ , ALFA 75
fully mappable engine management system
Fully made up loom replaces old motronic set up and allows removal of restrictive air flow meter , idle valve , cold start injector and distributor
Connects up to std crank sensor on front pulley with 60-2 pattern on motronic engines only
Early engines had distributor triggered ecus ie no crank sensor on front pulley you will need to add at 60-2 trigger wheel and sensor or find a s hand front pulley etc of a motronic car
Kit includes most parts to run the eng inc at start up map from cars we have done
You will need to make new plug leads or use the std ones and fit new ends to suit Dis coil pack
Kit includes
Omex 710 ecu ,Throttle pot ,Coil pack ,Wiring loom Air filter, Distributor Blanking plate and drive Air temp sensor
This kit will also fit 24 valve engines fitted in SZ,75,GTV6s and can be used with std plenum or AHM throttle body kit
GTV6,SZ,ALFA 75 EMS KIT
3.5 ALFA 75
Kit price
£1499.00
Fitted and mapped
£2499.00
12v cams race and fast road made from steel blank POA
DIZZY COVER AND BEARING FOR 12V
ENGS RUNNING D.I.S ING systems
This neat cover has bearing and shaft to hold the oil pump drive down when distributor is removed for EMS using no distributor
£130.00
3.8 24V FORGED PISTONS 101MM WITH RINGS AND PINS 10.5 OR 11.0 TO 1 CR FOR STD HEAD VOLS POA
Set of 6
V6 12/24V 101MM 3.5/3.8 Liner POA
Set of 6
V6 12V 101MM 3.5 FORGED PISTONS
FOR 11 to 1 CR WITH STD HEAD VOLS
POA
Set of 6
ARROW steel rods v6 12v and 24v
inc 3.2 GTA
£1440.00
set 6
AHM 12v/24v inlet manifolds for 45mm throttle bodies
Pic above 12V 3.5 SZ fitted with AHM throttle bodies
£285.00 set
AHM V6 THROTTLE BODY KIT 24V AND 12V
Kit is available with Motec or Omex E.C.U 12/24v
Also Available with Carbon Trumpets for some applications and different lengths 45x45 45x65 45x90
Kit Includes inlet manifolds/air horns/fuel rails -6/45mm t bodies linkages fuel rail mountings throttle pot
Injectors not included
£1400.00
Kit
AHM 1000 24v 24v Cams race and fast road made from steel blanks
Reprofiled we will need your std cams in exchange
New £1300.00
Reprofiled £400.00
AHM 24v V6 valve spring,base and Titanium cap set for std valves lengths and cotters
Can be use with std hydraulic lifters
£708.00
AHM 24 3.0/2.5 valve solid tappet conversion £576.00 plus vat
Convert you 24v engine to solid tappets for higher revs as std hydraulic tappets can fail
Kit is for std valve lengths and std cam base circles,shims come over sized so need to be sized to suit
Average shim size is approx 3.0mm Shims supplied at 5.0mm
kit includes cam followers, shims
£576.00
24v valve pack Fast road/race for use with std hyd lifters and std cottors or can be used with solid lifter kit above £1396.80
PART NUMBER
DESCRIPTION
PRICE
8v Boxer Engine Parts
BACK TO APPLICATION LIST
AHM 8 valve race big valve pack
kit includes
valves/springs/bases/caps/cottors
followers & shims
£749.00
AHM 8 valve uprated valve spring set for
std valve set up mec (camshafts only)
£100.00
AHM ARROW STEEL RODS FOR STD STROKE 72MM
OR 2.0L
2.0L PLUS £10 PER ROD
£235 EACH
£940 SET
AHM Steel race flywheel and 5.5" AP twin plate clutch
Parts include
flywheel/clutch/drive plates & bearing
£925.00
AHM Clutch bearing for race 5.5 " AHM
flywheel and clutch set up
£150.00
AHM Vernier pulleys for on 8 valve boxer engines
£250.00
AHM AHM camshafts race and fast road made from steel blanks £599.00
pair
AHM 36-1 trigger wheel for EMS set ups £130.00
Oil seal retaining plates
Stops the seals popping out when heads fill with oil on cornering. Much neater then 2 big washers
£80.00
Gearbox Parts
AHM LS33 Limited Slip Diff unit. Can be supplied for any application from Road to Race use. Fully Adjusted to suit your needs. ALFA SUD AND 33 8 BOLT LSD
LATE ALFA SUD, 33 AND 10 BOLT LSD
£645.00 _________________ PHAT 33 |
Posted: Thu May 13, 2010 8:41 pm Post subject: |
You could offset the number plate like the new Alfa's , Adie made these from a 75 bumper with the added spacer just above the splitter, then had them narrowed to fit his 33 and a mold made. If you look at his race car its on it. _________________ PHAT 33 |
Posted: Fri May 14, 2010 8:09 pm Post subject: |
Eh?, now you not making sense, veloce bumpers were for a mark2, not a 3, so you would have to take a series 2 veloce bumper kit to fit a 3, is that mot modding Al?.
Also The deeper 75 bumper will give straight line stability with the splitter closer to the ground.  _________________ PHAT 33 |
Posted: Sat May 15, 2010 2:24 am Post subject: |
I know the Veloce bumpers were for a mk2 lol I am taking a ser2 veloce bumper to get modded to fit a ser 3
What i was saying was why they took a 75 bumper and modded that to fit when a 33 veloce bumper would fit straight on.
I see what you are saying about the 75 splitter, i have never seen a 75 and 33 veloce bumper side by side. _________________ x2 33 16v
Posted: Sat May 15, 2010 8:38 pm Post subject: car |
al i thought 75 and 33 veloce bumpers look the same and they have the same splitter lip and also i will get you some door cards .  |
Posted: Wed May 19, 2010 7:58 pm Post subject: |
Al do you want a black front Veloce bumper? free to collector. Maybe i can get it to you via Pat as he is coming this way soon??? Let me know mate. _________________ 155 sportpack
Posted: Wed May 19, 2010 9:19 pm Post subject: |
If you want to lend one out, with the possibility of it being repaired to make a perfect mould, then yer thank you, it may need re-spraying afterwards.
To get an estimate could you post some detailed close pictures of the bumper so I can email the guy for him to see what’s involved, I have 2 ser 3 bumpers I can take pictures of for the valley bit in the middle for the ser 3 grill. _________________ x2 33 16v
Posted: Wed May 19, 2010 11:10 pm Post subject: |
Yeah i'll put pics on here tommorrow (i might ring you for help Al, ) The bumper is yours to do with it as you please. _________________ 155 sportpack
Posted: Thu May 20, 2010 11:43 am Post subject: |
Thanks and thanks, it will just be used to make a mould, not modified and repaired. I would hate to waste a good bumper, so if anyone wants to buy it off you when its all done, the money will be yours. _________________ x2 33 16v
jattsta Alfasud
Posted: Thu Jun 17, 2010 9:12 pm Post subject: Veloce bumpers |
Big Al im in the market for a series 3 front bumper.
They look great on a series 2, and would be interested in buying one.
Have you any pics or links -just want to be sure they are the ones i think they are |
Posted: Thu Jun 17, 2010 11:03 pm Post subject: |
Hi jattsta,
I was trying to get a ser 2 bumper copied for ser 2 owners and get it modified to fit a ser 3, for ser 3 owners, I think you / Paul may have got a little confused
I have 2 ser 3 bumpers if that’s what you really want. 1 is red, was brand new, not even been polished and I went and damaged it on a low curb. The other one is silver which was damaged by being towed too fast in the wet causing a crash, where the towing eye was pulled ½ way across the front of my car along with the bumper and bumper irons and engine bay mounting points. _________________ x2 33 16v
jattsta Alfasud
Posted: Fri Jun 18, 2010 9:24 am Post subject: Veloce Bumpers |
I should of perhaps expalined myself better-sorry
I am actually looking for a non standard bumper for a series 3
I would be interested in a veloce bumper from a series 2 that is modified to fit a series 3
What would be helpfull is if you can post a pic of the veloce bumper |
Posted: Fri Jun 18, 2010 10:29 am Post subject: |
Maybe what Iain suggested, the bumper from AHM maybe to your liking. Alex "33 bits" did send me pics but i cant find them, could you re eamil them or post them up here please alex.
You could always look at the pics of my cars in the welcome section, there is a link at the bottom of my posts. _________________ x2 33 16v
jattsta Alfasud
Posted: Fri Jun 18, 2010 10:47 am Post subject: Veloce Bumpers |
Just phoned AHM and they dont make them anymore.
A Zender front spoiler would also do the job but they are as rare Heskey's goals for England!
The only off the shelf bumper i can buy seems to be this one
http://www.lester.it/en/articoli.php?c=10
What do you reckon?
Iv never seen it on any car apart from the one featured |
Posted: Fri Jun 18, 2010 12:32 pm Post subject: |
I have been looking at myself I like it kinda a mix of ser 2 and 3, I will have to get some quotes from the fiberglass guy and compare prices. _________________ x2 33 16v
jattsta Alfasud
Posted: Sat Jun 19, 2010 10:00 am Post subject: |
Iv gone ahead and ordered the Lester bumper
Its a bit pricey but i just hope its going to look good once its on my car!
Got a 10-12 day delivery wait |
