kman42 Alfa Arna
Joined: 19 Aug 2011 Posts: 6 Location: Queensland, Australia
Posted: Fri Aug 26, 2011 3:28 am Post subject: Mysterious solenoid connected to carby |
there is a solenoid mounted on the firewall of my 33, A big cylindrical thing which a vacuum hose on the carby passes through. Anybody know what this is? Its not mentioned in the manual anywhere. The carby is the 32/36 weber fitted to the earlier models. Ive experimented cutting the power to it while the engines running, but there was no change??? Very curious
[/img] _________________ 1985 33, getting faster every day. |
JeremyC Gold Cloverleaf
Posted: Fri Aug 26, 2011 9:15 am Post subject: |
Is it an anti run on valve that dumps air in the manifold when you turn the ignition off? _________________ '93 Black 33 1.7 16v |
kman42 Alfa Arna
Posted: Fri Aug 26, 2011 9:34 am Post subject: |
Possibly, I cant be sure without asking an Alfa mechanic and its not an issue, just a curiousity. However, the carby already has an anti-run on solenoid which cuts fuel to the idle circuit when the ignition is turned off, so it would seem like a redundant system _________________ 1985 33, getting faster every day. |
baiones Alfa Sprint
Posted: Fri Aug 26, 2011 2:52 pm Post subject: |
I dont know if that is what i'm thinking, need a picture to confirm, but i think it's related to the AC compressor, to change the spark timming ( ignition advance )...
Is it between the carb, and the distributor vacumm piece? _________________ Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... ) |
kman42 Alfa Arna
Posted: Sat Aug 27, 2011 12:49 am Post subject: |
Its the cylinder at the bottom left of the photo _________________ 1985 33, getting faster every day. |
baiones Alfa Sprint
Posted: Sat Aug 27, 2011 10:49 am Post subject: |
Ok, it's not the same thing i was talking about...
That i dont know what it is... _________________ Carpe diem!!
Baiones
Posted: Tue Aug 30, 2011 7:19 pm Post subject: |
my old renault fuego had a solanoid attached to the weber carb which was a fuel shut off if the car had rolled on to the roof, it looks simular just not in the same place. _________________ PHAT 33 |
