dinko Guest
Posted: Sun Sep 07, 2003 12:00 pm Post subject: wiring questions |
| I just have a couple of simple questions. I need to know which colour wires are for what!!!!!! I actually only need to fiond the ground wire....but i dont know where to even start looking....so can soembody tell me where and what i should b lookin for...thanks |
Posted: Sun Sep 07, 2003 3:52 pm Post subject: |
Which model of 33, and which earth wires? There is normally an earth from the engine then bolted onto the bodyshell (front bulkhead) before going to the battery -ve terminal.
dinko Guest
Posted: Mon Sep 08, 2003 3:17 am Post subject: |
| its an 1,7 year 92model...thanks for the explanation but í still dont really understand what i should be lookin for...is it a normal wire and does it have some special colour???and if i want to connect it to something inside my car how do i do it? |
Posted: Mon Sep 08, 2003 10:38 am Post subject: |
It is a large diameter (7~10mm outside diameter) black cable. It bolts to the engine near the starter motor, then comes through the bulkhead and up to the battery. I will try and take a picture for you on my P4 if you give me a day or so (if I forget then please remind me).
Posted: Mon Sep 08, 2003 10:56 pm Post subject: |
All earth wires should be black or with a black tracer. There are three bolts for earthing auxiliaries on the l/h end of engine bukhead near the fusebox. Any black wire attached to the body is earthing something.Make sure all these have clean contact.
Regards Eddie |
