RpmHead Alfasud
paddy granger Alfa Sprint
Posted: Mon Jan 05, 2004 7:23 pm Post subject: |
and it is for sale!!
Is it based on a 1.7 16v with cylinder wall liners? |
Adam H Alfasud
Posted: Tue Jan 06, 2004 9:07 pm Post subject: |
I don't know, but it'd look simply superb under the bonnet of my car!
I guess it is too late for santa now - anyone got a winning lotto ticket? |
Errol Alfa Sprint
Posted: Wed Jan 07, 2004 12:03 pm Post subject: |
I WANT ONE!!!!!!!!!!!!!!!!!  _________________ 91 Alfa Romeo 33 16v * SOLD*
Lowered 45mm
15 x 7 inch advanti wheels
Falken 195 low profile
K&N Pod filter
Posted: Wed Jan 07, 2004 1:38 pm Post subject: |
No Errol
Me first what is a sexy engine
that'll go well in the old bagger  _________________ WODA WE NEED? MORE POWER!!
Maze123 Alfasud
Posted: Sat Jan 10, 2004 9:34 pm Post subject: |
Anyone who has asked for the price?? And does anyone has the german skills to translate the changes which have been done, cause I don't..!!? I've tried a few web-translations, but they don't know the technical words... _________________ Alfa 33 1.7 16v '88 QV
serpent Guest
Posted: Thu Feb 12, 2004 1:56 pm Post subject: |
I'd like to know how much is it too. |
James Granger Alfa 33
Posted: Fri Feb 13, 2004 6:44 pm Post subject: |
I guess about 5.000 euros - not sure, though. |
Guest Guest
Posted: Wed Feb 25, 2004 2:37 pm Post subject: What an engine |
Looks to me like this engine has had some serious money spent on it, the spec looks to me to be:
Motor Type: 4 cylinder boxer
Capacity: 1593 cc
Bore: 87mm
Stroke: 67mm
Compression Ratio: 11.0:1
It has crankshaft pulley driven dry sump lubrication with custom made aluminium sump
All steel forged balanced crank, works type (from what I can make out)
45mm throttle bodies linked to electronic engine management with fuel and ignition timing control and vernier cam timing
225HP at 9,100 revs, 11,000rpm red-line
The capacity is achieved by using the 1700 standard bore with a shorter throw crank, actually slightly shorter than the 1500 engine, the 1500 block can apparently be bored to 87mm and with the standard crank gives about 1600cc.
I suspect that this engine cost well in excess of £5000 as that is probably not even the cost of the parts alone! |
