Dicko Guest
Posted: Sun Jan 11, 2004 1:57 am Post subject: Timing belt change..... problems. |
hI all...
really need some help here....
Changed the belts on my SUD . I had trouble and managed to rotata the engine a few times while trying to get the belts on right. When I finaly got the job done.... the motor turned over by hand ok.... but woulnt start. ... instead backfired occasionly out the air filter.
I read recently (cant find again) that it is possible to put the belts on with the timing 180 degrees out. I think this is it.
I being the risk monger I am. Swapped the left and right spark plug banks. The car started ok.
Running on three cylinders...... changed a plug and back to four cylinders.
BUT..... now my engine is blowing black smoke......
ouchh...
Any ideas..... should I take the belts off and re do the job.... rotating the engine once before re - fitting????
Rich  |
dicko Guest
Posted: Sun Jan 11, 2004 5:07 am Post subject: fixed...pls excuse the lazy fool. |
Re did the job with piston one under compression.... back to normal... interesting that it worked at all the other way..... one clockwise rotation of the engine and re belted.  |
