Chris Guest
Posted: Thu Mar 25, 2004 9:49 am Post subject: 33 16V air flow meter wanted!! |
As you've probably seen by my entry in "General" I'm having problems with my air flow meter!
Does anyone have a second hand one from a broken car that they know is in good working order!?
Any help in my such is much appreciated!
Regards!
Chris |
loui Alfasud
Posted: Thu Mar 25, 2004 12:21 pm Post subject: Got one |
Have a spare on from a low milage 33 that was running fine before I ripped the engine out for my Mk2 16v carb conversion.
Its a Bosh Jetronic part - 0-280 000 615.
www.stopthemetalmaggot.co.uk/parts.htm |
Chris Guest
Posted: Thu Mar 25, 2004 12:34 pm Post subject: |
Sounds good!
I'll go and check the part number in an hour or so and maybe give you a ring!
Thanks! |
Chris Guest
Posted: Thu Mar 25, 2004 3:26 pm Post subject: |
Loui,
I've checked the number on top of my air flow meter, and it reads 0280202206
Does this mean that the one you have is different to mine? I would have thought that they used the same one for all the 33's
Does anyone know if I have to find one with the same string of numbers on it?
Chris |
loui Alfasud
Serpent33 Alfa Sprint
Posted: Wed Mar 31, 2004 2:37 pm Post subject: |
| Chris wrote: |
Loui,
Chris |
They are the same _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
