jmmoss Alfa Arna
Posted: Sat Apr 24, 2004 7:10 am Post subject: Replacing Your Fuel Filter: How often, and getting the part! |
Hi there,
My fuel filter looks like the orginal one from the factory (it has Milano, Italy stamped on it). I have read you are meant to change them once a year to avoid clogging leading to power loss, hesitation and hard starting. But where can you get the right one for the 33? No auto stores seem to have them listed, could I just by one that looks the similar shape and size? How often should they be replaced on the 33? Thanks,
JON |
Posted: Sat Apr 24, 2004 3:44 pm Post subject: |
My Alfa uses the BOSCH fuel filter as it has the previous electrical system. It depends whether you have such system or the IAW which the filter looks differently.
Normally it is replaced every 40000kms but it is a good practise to replace it earlier at 20000 or even at 15000kms since petrol deposits and dirt can ruin your fuel pump which is a rather costy part (around 200€).
Also when I replaced mine at 30000kms it was amazing how much less noise was generated by the pump
So it is better to be safe than sorry for replacing the filter at much shorter intervals for such its price (20€).
