-=QV=- Alfa Arna
Joined: 25 Apr 2003 Posts: 10 Location: Maastricht, The Netherlands
Posted: Fri Feb 20, 2004 5:46 pm Post subject: advice please!! |
Hi there,
I own an alfa 33 1.7IE from 1992. Now....the problem that I am facing is my coolant fan and housing (fitted to radiator). They seem to be broken as in making alot of noise!! I want to replace them, and here comes my question, with a cooling fan and housing from a alfa 33 1.7QV from 1988??
Maarten _________________ Alfa 33 1.7 IE '92 |
James Granger Alfa 33
Posted: Fri Feb 20, 2004 7:11 pm Post subject: |
Should fit - but I don't really know. |
Buck Bundy Alfasud
Posted: Sun Feb 22, 2004 1:33 am Post subject: Is it the right size? |
It's possible that the earlier fan will be bigger than yours, as the earlier car had a slightly higher bonnet line, so the rad might have been a bit bigger. You should be able to check that quite easily with a ruler!
Other than that it's just a case of checking the mountings will fit. Electrically it should be fine.
Buck _________________ Sprint Veloce 1.5 - Ebay £310!!! (In need of TLC) |
-=QV=- Alfa Arna
Posted: Sat Feb 28, 2004 2:59 pm Post subject: Re: Is it the right size? |
Buck Bundy wrote: |
Buck |
Thanx, removed fan today and mountings on series 2 fan are not compatible. And there's no room for fanmotor, because of powersteering pump.
Another problem solved......
-=QV=- _________________ Alfa 33 1.7 IE '92 |
Posted: Sat Feb 28, 2004 10:23 pm Post subject: |
If you need the parts just email me! I can arrange them to be sent to your door in Maastricht directly!
Are these the parts that you are looking for? |
-=QV=- Alfa Arna
Posted: Sat Mar 06, 2004 8:29 pm Post subject: |
James Granger wrote: |
I already ordered a new one, but thanx anyways James
Greetz _________________ Alfa 33 1.7 IE '92 |
