Ian M Green Cloverleaf
Posted: Mon Dec 22, 2003 12:09 pm Post subject: Rubbing noise |
Anyone got any ideas?
When cornered fairly hard (like going around a roundabout) I get this rubbing noise from somewhere and not sure where it might be.
Sounds to me like tyre rubbing under arch.
Only does it turning right.
Had a quick goosey underneath but didnt see anything broken.
????????????????????????????????????? _________________ Presntly own
Red Abarth 500c |
Eddie W Alfa 33
Posted: Mon Dec 22, 2003 9:08 pm Post subject: |
Hi Ian
I've had the same when cornering hard particularly if there is a bump. Pretty sure it is the front mudflaps . I suspect my front shocks are getting tired although they feel reasonable when I bounce them static.
kevnz Alfa Arna
Joined: 03 Jul 2003 Posts: 16 Location: Auckland New Zealand
Posted: Tue Dec 23, 2003 9:43 pm Post subject: |
Snap! I have an intermittant dry grinding noise on cornering. I thought perhaps one of the brake pads was rubbing on the disk, I couldn't see anything wrong either |
Paul Guest
Posted: Thu Dec 25, 2003 12:43 pm Post subject: exhaust? |
First try to see if there are no rubbing traces on tires or wheelarches. I had a similar problem too and seemed it was the exhaust tip rattling againts my rear bumper when cornering hard. Took me a long time to discover that, but prob was solved with new rubbers. Maybe something to look at too...
Regards!
Paul D. |
Scott Sander Alfa 33
Posted: Thu Dec 25, 2003 11:45 pm Post subject: |
Inspect your chassis rails for cracks. Hard to say what it is without listening to the noise.
If you think it is your tyres rubbing, use a bit of chalk on them and when it makes the noise stop and inspect to see if the chalk is still there, oh no point putting it on the tread _________________ Scott Sander
http://www.sanderfamily.com |
Posted: Sun Dec 28, 2003 1:50 pm Post subject: |
Thanks for the advice guys...as soon as the weather improves I will get under and have a good look round.
I was wondering if it could be caused by lateral movement due to worn bushes on the back axle? _________________ Presntly own
Red Abarth 500c |
Posted: Thu Jan 01, 2004 11:08 pm Post subject: |
HAd a similar problem after swapping some wheels over. It was the inside edge of the rear n/s tyre rubbing on the petrol filler pipe.
