Reis Alfa Arna
Joined: 21 Jul 2004 Posts: 10 Location: Almada - Portugal
Posted: Wed Jul 28, 2004 12:17 am Post subject: Alfa 33 1.5 IE (cat) |
Hello ! Anybody with a alfa 33 (III series) 1.5 ie (CAT) ?? The max obtained is 3500 RPM, then cut off (shouldn't be aroud 6000 rpm ?) Could be the motronic system ? If you know the answer pls inform. thks ! |
zorba128 Alfa Arna
Posted: Wed Jul 28, 2004 7:49 am Post subject: |
just watch the speedometer - if you reach almost 60 mph (100km/h) on 2nd gear than it's ok - just the rev guage readings are false. cut off should be above 6000, 3500 is only "just above idle"
greetings
marcin |
