Yvon Alfasud
Joined: 22 Apr 2003 Posts: 31 Location: Wavre, Belgium
Posted: Wed Apr 23, 2003 8:05 pm Post subject: Initial advance on a 33 16V |
Still working on my ratling problem and was trying to locate the advance update feature to check for broken hose or electrical problem.
How intial advance is modified between idle and runing state? Is the rotor equiped with an Hall effect sytem ? Did not see any electrical connector.
TIA
Yvon |
Posted: Thu Apr 24, 2003 12:00 am Post subject: |
For the 16V all the timing is controlled by the ECU, with crankshaft position determined using a sensor on the flywheel (fitted down on the side behind the cylinder head on the drivers side of a lhd car)
RickD Guest
Posted: Mon Apr 28, 2003 9:00 pm Post subject: |
Electronic Central Unit ..... autrement dit Le Calculateur de l'injection qui se trouve au dessus des pieds du passager et derričre la boite ŕ gants. Sorry to answer in french
Yvon |
Posted: Tue Apr 29, 2003 10:25 am Post subject: |
No problems. Could understand it, even if I couldnt have written it in French
