baiones Alfa Sprint
Posted: Mon Sep 20, 2004 11:38 pm Post subject: 33 ignition CUT |
At which rev does your 33 16v CUT ?
6800
7000
7200
Wich is the factory cut ? _________________ Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... ) |
Mixsynth Alfa Sprint
Posted: Tue Sep 21, 2004 12:32 am Post subject: |
The factory limiter cuts in at 6800.
I never actually touched the rev limiter in mine - mainly because I was too scared of blowing it up (I had no idea how old the cambelts were and never got round to changing them) - so I never saw the rev limiter work. _________________ Hugh B
'98 145 QV
baiones Alfa Sprint
Posted: Tue Sep 21, 2004 1:29 am Post subject: |
Why the hell some say its 6800 , others say 7000 , and others say 7200 ?
Is it there on the 16v owner manual ?
There's even a Portuguese mag that says 6750....
Which is it after all ? _________________ Carpe diem!!
Baiones
Marcin Alfa Sprint
Posted: Tue Sep 21, 2004 6:59 am Post subject: |
| baiones wrote: |
6750? 6800? This ain't no pharmacy...
Marcin |
Posted: Tue Sep 21, 2004 9:37 am Post subject: Re: 33 ignition CUT |
| baiones wrote: |
6800
7000
7200
Wich is the factory cut ? |
It is 6750-6800 depending year and maket.
Anything above that is tuned. _________________ Tino Vatavuk
Posted: Tue Sep 21, 2004 6:18 pm Post subject: |
If you get a Squadra superchip the rev limit is increased to 7300, apparently _________________ Hugh B
'98 145 QV
Laki Alfasud
Posted: Wed Sep 22, 2004 12:42 pm Post subject: |
I have a manual at home and it says 6800rpm....max bhp on 6600rpm.... _________________ -- ALFA ROMEO 33 Q4 --
Bellamachinna Alfa 33
Posted: Wed Sep 22, 2004 2:52 pm Post subject: REV LIMITER |
Hi...
My 16v cuts at 7200Rpm...
I had some trouble with rev counters, im going on my 3rd...One even indicated the cut at 4500Rpm.
The original item indicated 7200 then started failing indicating no revs at all...
The 2nd one started fine, until it started to indicate less revs (cut at 4500 )
Its my belive that all 16v (no Cat) cut at 7000/7200 Rpm-Not Before that-If they cut before, maybe you ´ll have some trouble-Can even be the rev counter....
Paulo Camilo
Boxer 16v QV |
Sergio Alfa Sprint
Posted: Sat Sep 25, 2004 9:09 am Post subject: |
Well mine is a non-cat version 16v QV and it cuts at 6750-6800rpm....
Like Tino says, I beliece anything above that is tuned... or maybe the revcounter has gone wacko
all the best
Sérgio |
