Posted: Fri Dec 03, 2004 12:08 pm Post subject: Replacing Cambelt |
I'm about to embark on a cambelt change....
So I thought I'd give you all the chance to brag on how quick you can do it, before I get started! _________________ Fiat Bravo 165 Sport |
LDA Alfa 33
Posted: Fri Dec 03, 2004 12:11 pm Post subject: |
did it on an mr2 turbo the other week. omg that was hard work. we had to take the engine out to do it!!! took me 2 days! to get the belt on and then i still had to put the lump back in!
not tried it on an alfa yet. but when i build a turbo lump i'll have to do it.
good luck, and do post back to let some of us people know where you got stuck and what to look out for.
LDA Alfa 33
Posted: Fri Dec 03, 2004 12:12 pm Post subject: |
oh and tippex!
mark the cams wheels with tippex and a little mark on the block too. so you line them up if they get moved.
evanbottcher Alfasud
Joined: 12 Mar 2003 Posts: 53 Location: Melbourne, Australia
Posted: Fri Dec 03, 2004 12:56 pm Post subject: |
Under the cam covers there is a notch at the rear of the cam housing that lines up with a notch on the rear of the cam itself, they line up when cyl 1 is at TDC on compression. It comes with it's own tippex!!!
 _________________ http://www.trofeoalfasud.com
'77 Alfasud Ti
'69 1750 GTV |
Posted: Sat Dec 04, 2004 12:28 am Post subject: |
I hope you're going to change the belt tensioners too so your engine doesn't self-destruct like mine did! 5 months after the garage replaced the timing belts, the motor started sounding and running bad and then crack bang, I needed a replacement engine.  |
johnboy 16 Valve
Posted: Sat Dec 04, 2004 5:46 pm Post subject: |
LDA
if you check old posts by me and others you should find how to do 16v belts.this is the only car i have ever done the the belts on.its easy when you know how too.i killed 8 valves on one side and bent one on the drivers side which a mate straightened. but it was only slightly bent.i rebuilt the engine in the car in the road out side the house. that was a year ago and she still fine!
1999 freestyle superjet |
