LDA Alfa 33
Posted: Mon Dec 20, 2004 4:50 pm Post subject: gearbox rebuild |
hey all,
i've recently learnt a lot more about the insides of gearboxes. to further my knowlege i'd like to take one apart and rebuild it.
is this a DIY job? assuming that the box is mostly working when i start working on it, do i need hundreds of pounds worth of parts or are they all quite cheap?
any special tools? i have an extensive socket set, rachet spanners and a torque wrench.
also any gearbox manuals/info would be good. any one knwo where i might downloads some?
i'd like to rebuild a perm 4 box but only if i can find one cheap. failing that any 5 speed fwd 33 box will do.
Posted: Mon Dec 20, 2004 4:52 pm Post subject: |
I am able to supply you with the manual you need for your box. Wizz knows deeply about rebuilding gearboxes.
Wizz Alfa Sprint
Posted: Tue Dec 21, 2004 8:30 am Post subject: |
Hi LDA.
Have a look at this thread: Anybody tried fixing the synchro on the gearbox? - I did! .
The parts I used, worth approx. £250:
- 5 Synchronizing rings
- 1 Speed control fork (the one between 1st and 2nd was pretty busted)
- 1 Nut (The big one at the outer part of the axle)
- The usual assortment of gaskets and stuff.
Special tools: No, not really. But you do need a rather large wrench for the nut at the rear of the main axle.
Having done it myself, I'd say it's a DIY job. _________________ //Wizz
Alfa 33, 1.5 IE (1992) (Series 3)... now with 1.7 IE |
LDA Alfa 33
Posted: Tue Dec 21, 2004 1:47 pm Post subject: |
hey wizz.
i spent ages last night reading you topic on your gearbox rebuild. very good stuff. i also down loaded all of the photos
i think i'll have a go myself. i may need to ask back here once i have the box in bits to work out exactly what new spare parts i need. but i spose thats all part of the learning process.
any one know if there are any uprated synchro's for our box or ones that could be put in from another box? it would be nice to prolong the life of my rebuilt box as long as possible.
Wizz Alfa Sprint
Posted: Wed Dec 22, 2004 8:17 am Post subject: |
Hi again.
Glad you liked the photos and have the guts to give it a try.
I've heard of someone using the syncros from a Fiat Punto.. But I don't know whether that would be an improvement or not. I suspect they might just be similar to the 33 ones. _________________ //Wizz
LDA Alfa 33
Posted: Wed Dec 22, 2004 2:34 pm Post subject: |
wasnt there a punto turbo? that has got to have uprated synchros compared to the 33. right off to find a fiat forum.
