Rust Above Windscreen
John Hansen
PostPosted: Mon May 05, 2003 12:29 pm    Post subject: Rust Above Windscreen Reply with quote
Would appreciate any comments on easiest way to remove/lift top of windscreen away from roof so that I can sand and remove a few rust bubbles before they become nasty cancer. Sad
Thanks Very Happy
John H
'87 Alfa 33 QV
33 don,t rust
PostPosted: Tue May 06, 2003 10:49 pm    Post subject: fish oil Reply with quote
fish oil i spray all my fust spots with fisholine the moment they appear
slows it down at least
Gary UK
PostPosted: Wed May 07, 2003 1:09 am    Post subject: Reply with quote
If you mean the rubber then hold it back with a SMALL blob of super glue(If you can't actually bend it back over and stick it to itself then use a small piece of metal glued to the front lip and the back(windscreen side) of the rubber) once you have sanded and sprayed the rust spot then using a sharp craft knife cut the glue from the rubber.
