Alfa33P4 Alfa Arna
Posted: Sun Oct 02, 2005 11:09 pm Post subject: p4 noice from central axis |
Hello Alfisti
I'm Owner of A33 16V P4 and i have a problem to central axle.Whenever i turn full lock i feel a vibration.I change all universal couplings the noice reduced but not disappear my tyres are same dimension and same pressure. _________________ A33 16v P4,A155 Q4,Alfetta sedan 1.6 |
Posted: Mon Oct 03, 2005 7:57 am Post subject: |
It is normal for P4 to vibrate a little when on full lock, loud bumping/knocking is not. It is because there is no real centrall diff like in 155 Q4 (you owner of 1). So difference in rear front speeds/turning circle is compesated by rear tires skiping portions of ground.
New rubber visco coupling mounts would help maybe a little more, but if it's only more then small amount of vibration. _________________ Tino Vatavuk
Posted: Tue Oct 18, 2005 10:19 pm Post subject: |
tvatavuk wrote: |
New rubber visco coupling mounts would help maybe a little more, but if it's only more then small amount of vibration. |
Unfortunatly it seems they are no longer available (along with P4 petrol tanks, bolts to hold P4 rear calipers on, P4 rear gearbox mounts, etc).
Posted: Wed Oct 19, 2005 10:17 am Post subject: |
Unfortunaly they are no longer in production for more then 3-4 years, but from time to time some parts can be found with bit of luck and if you look hard enough.
We should probably make all over the world (every look in ther country) search for those parts and buy them, but I know that it will never happen. _________________ Tino Vatavuk
